Cruzan80
Picked up a Snap On mid-rise scissor lift (either a EELR300A, or a 6000A) a bit ago, owner said it needed work. First discovered the motor/pump connection was missing, replaced coupler (explains why it wasn't working before).
Below is how I got to this point. Right now, the lift is 90+% up, and not coming down at all. Tried pressing the button/lever multiple times, even took out the lever assembly, and both check valves. Biggest culprit remaining is debris in the 90deg velocity valve at the bottom of the piston. How do I access this without either bringing the lift down on top of me, and/or making a mess releasing the rest of the hydraulic fluid when I loosen the fitting?
Beginning Steps:
Initially filled the tank with new oil, was tripping the breaker at the beginning (on an extension cord). Took off the hose, and ran it for a few seconds until I got fluid out of the pump. Then hooked up the hoses, and began to fill the lift. It slowly started up (no load for first test). When it was about 70% up, it ran out of fluid, and I added more to the tank. Got it almost all the way, 90+%, and the bottom side of the piston has a blast of air with a bit of oil spray. Is this just self-bleeding? Kind of sounded like if the safety release on a compressor opened. Waited a min, lifted a bit again, worked. There is a bit of oil dribbling out of that hole, guessing new seals (piston and gland) are in the future. Cheapest I saw was about 150? (00181 and 00183 are parts nos).
Beginning Steps:
