Stud finder
caps
Can anyone recommend a good stud finder for a decent price? I had a black and decker thay was given to me, but it was horribly useless.
I hate tapatalk - but this was posted from it.
Trey T
Houston, TX
CH Hanson magnetic stud finder. It find the screw/nail behind the drywall. Works great! It's my to-go stud finder over my electronic one.
Grab couple of them.
Ign
Butte Peak ND
I have a carpenter buddy who does nothing but, well, carpentry 40+ hours per week and swears by this CH Hanson unit.
As for the "electronic" ones, I've had a couple Zircons that always worked well enough. I've also got the Ryobi 4V one and it's fine - has a fancy screen which is supposed to show you where the stud starts, ends and center, but it's nothing but an overly complex version of the run of lights on Zircons.
Honestly I'd try the CH Hanson model instead of something that relies on batteries, lights and electronics.
capswin
Baltimore
The problem that I have is that every time I try to use a stud finder, it points back at me!
C
caps
^I like this guy, he understand my problems.
BlindViper
York, PA
I use the flash light I carry on my side. 99% of the time no drywall is perfect and I can find every nail or screw. Unless wall paper is involved then I just use my knuckle.
thebeekeeper1
Illinois
I have a very old (20+ years) Zircon that has always done the job. I haven't felt the need to look for a new one.
I bought the top-of-the-line Zircon six or eight years ago and have been very pleased. It was close to $50, so not too cheap, but it works really well. :)
rharman
SoCal
+1 on the Franklin.
I originally bought it hoping it would "see" through my stucco exterior. Not so good at that but it is great over drywall and lath & plaster.
Got $25 back from Amex as I bought it on "Small Business Saturday" last year. Couldn't pass up that deal. Timing was perfect.
Givl Reggin
Hawaii, USA
It seems like I always end up buying a new one every 8-10 years, as the technology improves. But, I've yet to find one that is absolutely perfect each and every time... most have problems when it comes to double studs or horizontal blocking and you can forget determining the size of a lintel above an opening.
The first one I used (~40 years ago) had a floating magnet inside to detect nails. The main problem with this is you really don't know if that nail is barely on the edge or in the exact center of the stud.
The newer ones use capacitance to detect the actually stud, that is if it's not too deep. Most of these have a backup mode to detect metal (nails/screws) when you have more than about an inch of drywall.
Some of the more advance ones can even tell the difference between between studs/wire/PVC/pipes in the wall, like this Dewalt unit...
http://www.amazon.com/exec/obidos/ASIN/B00ACF6QTC/awh
I think Milwaukee also makes a similar unit.
I don't think any of these are worth a damn when it comes to lathe/plaster walls, but I would love to be proved wrong! :)
metaldad
nw indiana
I generally use one of these. :lol_hitti
thebeekeeper1
Illinois
My Zircon has a "Deep Scan" mode that works quite well over thick coverings. I haven't used it a great deal, but it has been accurate when I needed it.
rharman
SoCal
I've been doing that same trick on my wife for years and years. She still laughs and agrees with me.
Gotta love that.
Oldsmobiler
Coquitlam, BC
saw a guy take a tape covered speaker magnet and run it all over the wall...then he took a grinder with a bolt and showered the wall with sparks...the shavings stuck to the heads of the screws like glue! OLD school steel stud framer...love the tricks they use
Jomo
Kingston, WA
+1 for Franklin Sensors.
Much easier to use than previous Zircon types.
3 hands no longer required.
Love it!
RKA
+1 for the Franklin, but haven't found it particularly useful on lath and plaster. On sheetrock it's great.
