Stud Finder
drx2
Any recommendations to find metal studs through 5/8" drywall? Was hoping to get one that will work for wood studs also. Will a magnet work with that thickness of drywall? Thanks in advance.
nbpt100
Massachusetts
A good magnetic stud finder will find steel nails and screws. I assume it will find steel studs. I have never used one for such an application. I have a Franklin Professional stud finder that will identify metal or wood studs. You can go on their website and look up the specs for each model. I dont recall which one I have. It also identifies if live wires are near. That feature seems a bit too sensitive as it flashes when I know there is not a wire immediately behind it.
djbmw
Ottawa, Ontario, Canada
If you have access to a thermal camera... they work great as well for seeing studs. If you dont already have one then... they are about 20x the cost of a standard stud finder lol... but they let you see all the studs behind a wall at once :)
seber
Deep East Tx.
I've tried four or five different brands over the years. None of them are as reliable as tapping a hammer against the wall and listening.
danski0224
Near Naperville, IL
I believe your problem will be locating the metal, as stud finders are tuned for wood. There are radar models that may work, but have not used one. Then there are the magnet tricks.
A light shone at an angle to the wall can highlight screw depressions.
I have not had too many issues with this one (there are newer models):
I also have an old Zircon with an LCD display and it finds the stud center.
Fresh batteries are important.
The Franklin models do not require "calibration", which is nice.
Rusted Nut
PNW
Go to a drywall supply store and they will have a cow magnate on a string. Works very well on even two layers of 5/8”.
bassJAM
Cincinnati, OH
engineer2
Chicago burbs
I gave up on electronic stud finders and now use the magnetic kind. I have a thermal imager and it works great in the winter, don't know about the other seasons.
rharman
SoCal
This looks like a gimmick but I've had better luck with it than the Franklin.
dscheidt
Rack-A-Tiers 52300 Studball, Colors may Vary (Basic Pack) https://www.amazon.com/dp/B00JV3JNE6?tag=atomicindus08-20
Got on the recommention of someone here.
I've got old, thick drywall with texture over steel studs. Fancy stud finder that was supposed to be good for that depth and steel didn't work. Strong (square) magnets I already had around didn't work.
The studball makes it super easy.
I came here to recommend this. I've used mine to find lath nails behind 3/4" of plaster. drywall screws or nails are no problem at all.
alinc100
Dearborn,MI
Franklin's M150 stud sensor has worked great for us . We run into a lot of acoustical walls with double layer drywall and studs on resilient channel and the Franklin always performs. Available at Home Depot, Harbor Freight,Amazon,etc.
