Stud Removal/Installation Tool
Bull
How do these work? I don't mean qualitatively, I mean mechanically, what do you do with this tool?
Bull
Ok, so does that splined/knurled disk rotate, or is it fixed? The splines grab the stud and twist rotate it?
Dumb questions, I know, I've just never seen one before.
Danglerb
SoCal
Use two nuts torqued together. That thing isn't ten cents different from a pipe wrench.
Moose-LandTran
The Brink of Insanity (England)
Yes, the knurled disk can rotate, the pivot for it is not centred, but eccentric so the more torque you put on it, the harder it bites. The knurles grip the stud and allow it to be removed or installed. The stud passes through the hole.
Bull
Ok, I get it now, thanks.
But I guess if the same job can be done with two nuts, I should save my money and not buy this one!
tatra
pirate contest city
unless the threads are nfg..........have used them in the past and they do have their place..........like right beside you when you need it..........have used stud installers for truck wheel studs [ dayton style] and gotta say they are pretty slick and fast...........but two nuts are cool too........hmmmmmmmm liittle gay sounding...........using two nuts is manly..........nope..........rather use a stud installer............i can't win.........oh well off to pick a pretty colour for my...................:lol_hitti
rhandwor
If you can get to the stud they work fine but due to size won't always work. I would keep one around if you need them occasionally.
Uncle Buck
Kansas
Just like anything else, if you shop used long enough sooner or later you will run into one you can get for just a few bucks like most everything else, then you will be obligated to buy it!
krusty the clown
Member Emeritus
niangua, mo
for exhuast studs on older vehicles those are great. there isn't normally enough room on newer vehicles to use it. for studs you plan on reusing the assenmacher type is much better.
Bull
You swearing at me, Krusty?!
:lol_hitti
