Studded snowmobile on cement floor
Schu338
Ny
What do you guys use on garage floors to run a snowmobile out the door without damaging the floor? I already use the 3-wheel dollies for general moving around.
kenners
SE Wa State
I use a Harbor Freight dolly to support the drive end. I've made longer dollies for the skis using 1 X 4's and 2 X 4's and Harbor Freight casters. I can move them in and out of the shed whenever needed. Pull them up to the trailer and then remove dollies and ride up into the trailer.
Slednut
Washington state
I use a tire dolly for the rear and made my own steerable dollies for the front. I can move the sled around with one finger. I can leave the dollies on the skis when I run the sled onto a ramp or trailer. They hang up on the edge of the ramp and stop as the sled continues onto the trailer. The carbides runners on the skis never touch the floor.
For your studded track (I ride in the back country so I don't use them) with my setup you could probably get enough momentum to push the entire sled onto the gravel or snow and just start it up and drive off all three dollies.
ezridr60
Iron River, MI
Not a snow mobile, but a skid steer with chains. Summer storage in a pole barn with a dirt floor, winter in the garage, concrete floor. I used 2 sheets of 1/4” OSB. Cut em into 24” strips, 4 six footers, and 2 four footers. The 4’ strips I use at the entrance over the door lip, and slide em in after the machine is in. End of winter, just stack the OSB strips off to the side. Been using the same ones for more than 5 years, the 4’ pieces are getting beat up where the machine drops off the concrete onto the gravel drive.
Organized_Garage
Merton, WI
The Horse Stall Mat is great recommendation as is USB boards. I've heard folks also finding rubber truck bed mats and using those.
Ours are usually put up on their own lifts once returning from a trip. I have Racedeck Flooring in our trailer and Caliber Track Guide/Panels to protect. (photo below is stock photo from Ground Up Lifts website).
nh_yota
Seacoast New Hampshire
A 4'x8' sheet of plywood is just about the size of a 1-up sled. I would be more inclined to use a rubber stall mat because it won't shoot out from under the track if you give the sled too much gas.
