Okay everybody, I'd like your help because I'm tackling something that I know nothing about....
I got a big Record 75 vice last week that I'm nearly finished restoring (here). Because I'm still in a temporary garage, with limited bench space, and also because the vice is cast steel and has an anvil, I thought it would make sense to mount it on a stump.
Here's what I've done so far:
1. Lifted a stump from the back garden and cleaned it up
2. Set the stump on a level flagstone, propped the stump vertical, and scribed the base for a good horizontal cut line
3. Cut two cross-channels about 1/2" deep in the base, creating 4 feet for balance
4. Sanded the top flat and level, offered the vice plate until it had a flush bed, marked and centre-punched the fixing points
I'm going to give the stump a coat of white spirit once it has dried out - it's been sitting out back for three years, and I don't want to risk bringing any woodlice in with it.
Other than that, I was just going to drill out the fixings and attach the vice with some coach bolts - any reasons why that won't work, or any special/better way to deal with a stump
