Stumped by this Wayne Dalton iDrive Torquemaster opener problem
DIYorDIE
Okay, so a few weekends ago, I help my brother-in-law diagnose and fix his sprinkler system problem in 20 minutes instead of the two hours I was expecting it would take to find, dig up, and fix the wiring problem.
As I was walking out of his garage to put my tools away and leave, my brother-in-law asks me, “Do you know anything about garage door openers?” Well, since I’ve put in a couple in my houses in the past and diagnosed and fixed them – and since I’ve always been rather curious about his “iDrive” openers, never having seen one anywhere before, I told him, “I’ll take a look.”
Big mistake #1.
My brother-in-law has two single bay garage doors with two separate iDrive Torquemaster openers (a “north” bay and a “south” bay). The “problem” he was having was that the north opener’s motor was not dropping down into the vertical lock position after the door was closed. Other than that, it opened and closed the door just fine. The south opener worked perfectly – the motor pivoted up and down as designed.
Well, I thought I would be able to figure out the problem by just running the perfectly-working south opener through a few cycles to see how its operation differed from the north one and then be able to easily fix it. Well, nothing was immediately obvious. My brother-in-law had apparently been trying to diagnose it himself sometime earlier because he had already taken off all of the openers’ covers before I showed up.
With the covers off, I watched the potentiometer screw and sliding switch and thought maybe it was binding somewhere so I gave it a little shot of WD-40. No change.
After other unsuccessful efforts to find anything visually operationally different between the two openers, I thought I’d try to see if the south (perfectly-working) opener could automatically reset itself if the opener had been disengaged using the emergency release cable and the door had been moved before being re-engaged. I did this because my brother-in-law mentioned that he had pulled the emergency release handle on the north opener a couple of times when trying to fix the opener himself, and I thought maybe he had re-engaged the door in the “wrong position.” I was trying to replicate this on the south opener to see how the opener might “reset” itself.
Big mistake #2.
Here’s what I did (but shouldn't have done): :lol_hitti
With the door in the normal closed position, I pulled the emergency release on the south opener. I then easily manually raised the garage door all the way up into the full open position, and then re-engaged the door to the opener by releasing the emergency release handle.
I then pushed the button on the remote wall switch and got – nothing. I had expected the opener motor to cycle through, re-engage the torquemaster bar, and then close the open garage door. But it just sat there and did nothing. I don’t recall if I actually heard the motor try to operate at all or not.
Hmm, so thinking it was just a temporary glitch, I pulled the emergency release handle, pulled the door down manually into the closed position, and then re-engaged the door. I pushed the button on the wall switch again and got – nothing. Now, I was getting worried – what had moments before been a perfectly operating door now didn’t operate in either the up or down direction. (I had also tried adjusting the starting position of the potentiometer screw switch but that didn’t help.)
It was at this point my brother-in-law comes out of the house with the original paper iDrive installation and operation manual! Yeah, I know – RTFM first. I should have asked him for the manual at the very beginning but I thought he had lost it because he didn’t bring it out when we first started to work on the openers.
Anyway, I checked the Troubleshooting guide in the manual and right away spotted the cause and solution for the north opener motor not dropping down into the “lock” position – I just needed to back out the detent screw a bit. I did that and presto – problem fixed!
However, the original perfectly-working south opener was now the problem.
I read in the manual about the “Install” and “Profile” setting routines needing to be run and so I tried both of them with the south opener. I’m sure the opener is communicating with the remote wall switch because when I press the red reset button on the opener and then press the button on the wall switch, I hear the confirmation beep from the opener.
Yet every time we try to activate the south opener from the wall switch, we hear two beeps and one buzz coming from the opener, and no motor sound at all. The motor is completely quiet – it’s not like its gear is jammed or anything.
And yes, the wall outlet the opener is plugged into is live, and as a second test we’ve even run an extension cord from another known good outlet in the garage and plugged the opener into that and still no motor operation noise. All we get when we press the wall switch button are two beeps and a short buzz (a “buzz” and not a “chirp” like I’ve read elsewhere on the internet).
I know the motor in the south opener is not burned out because I’ve swapped it out with the motor from the north opener and both motors work when they are installed in the north opener, but neither motor works in the south opener so it’s not the motor itself.
I’ve tried to test the voltage readings at the circuit board outlet that the motor plug plugs into on the south opener, and when the wall switch is pressed I get varying readings from 8-24 volts on the north opener plug and about zero on the south opener plug. That tells me that it looks like no power is getting to the motor when mounted in the south opener. (I am still curious why the readings are not consistent in the first place, but at least the motor does work in that opener.)
I pulled the circuit board and tested the two soldered-in fuses (a small “resistor”-looking one and a tall thin “canister”-looking one) - both show continuity. I also visually inspected the boards for any obvious damage - no damage seen. The main board and the little soldered-on remote control receiver daughter board both have “2001” dates. The “Door Operator Model” is 3661-372; these openers were installed when my brother-in-law’s house was built around 2001 or 2002.
Since there apparently is no power at the motor plug on the circuit board, I was looking for possible circuit component issues. I noticed two identical twin relays on the board and searched out their specs online. I learned that twin SPDT relays are used to be able to power and reverse spin direction on motors so I’m thinking they may be the culprits.
I found a circuit diagram for these two specific relays posted online by the manufacturer and tested for continuity. There is continuity in the resting state of the relays, but I show no continuity across what I think are either relay’s coil contacts. I try powering each relay’s coil temporarily with a 9V battery but get no clicks and no change in the circuit that should be switched when the coils are powered. In summary, it seems like both relays may have burnt out the coils.
That’s still a little puzzling because even if both relay coils are burnt out, I would think the motor circuit in the resting state configuration would still work in one direction.
I was sort of hoping I could definitively pin the problem on the two relays because those parts are pretty cheap - $1.35/each + shipping (it costs more to ship them than to buy them). However, even with new relays, it might be an impossible fix because the remote control receiver daughter board is soldered into place less than ¼” above some of the relays’ contacts – I know my standard size soldering iron tip can’t get into that small of a clearance.
So, I’m hoping some of the Wayne Dalton iDrive “experts” on the Garage Journal – guys like NUNNSGT, ovilla, and AlanL who have commented on other posts – might be able to suggest some possible solutions to the situation I have described.
My brother-in-law and sister-in-law like these iDrive openers – they’ve had them in their house since it was built about 14 years ago and have not had any major operational issues until now. Since I apparently did something to cause the south opener to no longer work when it was working perfectly before, I feel obligated to fix it. I’d like to understand the real problem before ending up having to resort to buy an old system off of eBay since no one really services these things anymore. I’d hate to buy an entire replacement opener if it really was a “simple” problem and fix and I just didn’t know what to look for.
Thanks.
(BTW, I see many of the openers being sold on eBay are the later "3663-372" model with the more vertically-oriented 2-button wall switch instead of the wider, 5-button "horizontal" wall switch like my brother-in-law has. Anybody know if the older 2001 era remotes like my brother-in-law has will communicate without a problem with these newer openers? )
pattenp
Virginia - USA
I used to have a Wayne Dalton idrive opener and when you unlatch the motor the idrive knows the position of the door no matter where you reengage the motor latch because the torsion shaft still turns the position sensor inside the unit. Have you checked to see if the latch is fully engaging when the disconnect handle is returned to the motor operation position?
D
DIYorDIE
Thanks for the quick reply, pattenp - I saw your posts on the other iDrive threads, too.
Now that you mentioned it, I guess I never watched the position sensor move as I raised the door manually since I was standing on the ground and not on the ladder. I also don't recall if the geared teeth that are driving that position sensor screw drive are on the torquemaster bar but they must be since you said the position sensor moves even when the motor is unlatched using the emergency release.
If that's the case, then my original theory of what happened (the motor couldn't turn because it was trying to lift a door that was already in the fully-Up position after I raised it manually and relatched it, and the current for that stalled motor burned up something on the circuit board like the relays) can't be true. If you're correct in saying that the position sensor is always moving and correctly indicating the position of the door, even when the motor is unlatched, then the motor in my case would have known the door was in the fully-Up position and reversed to lower the door when I hit the wall switch that very first time.
As for checking to see if the latch is fully engaging when the emergency disconnect handle is returned to the motor operation position, I'm assuming you're talking about that plastic collar on the torquemaster bar that has the large "toothed" areas that engage. When I put the opener back into motor operation position, I manually rotate the torquemaster bar back and forth to make sure that collar engages, and once it engages I can make the motor swing up a bit if I manually force the door up a little. So yes, I think the latch is engaged.
Thanks for the idea, though.
(BTW, every time I try the wall switch with door in the Down and closed position, I first make sure the position sensor is back in its starting left position, within 1/8-3/16" of the full left stop. I've adjusted it numerous times and it still won't start. I've even removed the plastic screw drive and just manually moved the plastic position slider to different positions [with the motor unmounted and sitting on top of the opener but still plugged into the circuit board] while my brother-in-law pressed the wall switch just to see if I could get the motor to run. It never worked on the south bay opener, but I could get the motor in the north bay to run doing this manual test. And when I swapped motors and continued this manual diagnostic, both motors would run sitting on top of the north opener but not on the south opener.)
NUTTSGT
Northern Central Ohio
I replied to your PM.
I did forget to mention at one time one of ours had an issue of not working. It was only a few years old. After a lightning storm went through, I had to call Wayne-Dalton and describe the problem. The lady sent me a diode (or whatever it was) to replace which fixed the issue.
I'm sure you know by now that Wayne-Dalton was bought out by Genie (I believe) and a subdivision of theirs. Genie didn't want the I-Drive stuff because it was problematic or could be. I believe for most people, they either work great or are a PITA.
I spotted a NOS on CL a few weeks ago and considered buying it as a spare but forgot all about it until you mentioned buying a replacement.
koditten
Midland, Michigan
Out of the 5 people I know who drank the coolaid and bought these openers, every one has replaced them. Including me. Mine had a bad circuit board right out of the box. I may have got a full year out of it before it did exactly what you're did. The next weekend it was in the trash and replaced with a Genie.
I'm not even going to comment on how to fix it. Yes, they were that bad. You got very lucky to make it last this long. Cool.
D
DIYorDIE
"I'm sure you know by now that Wayne-Dalton was bought out by Genie (I believe) and a subdivision of theirs. Genie didn't want the I-Drive stuff because it was problematic or could be. I believe for most people, they either work great or are a PITA.
I spotted a NOS on CL a few weeks ago..."
I think I read somewhere that Overhead Door bought Wayne Dalton's door division but didn't want the opener division - they knew all about the problems with the openers and how professional garage door and opener installers wouldn't touch the iDrive openers because of all of the problems and incessant call-backs. So the iDrive openers were left to die on the vine without on-going support or replacement parts.
"NOS" - I kept thinking "Nitrous Oxide System" and had to look up the abbreviation ("New Old Stock"), LOL. Actually, there is a NOS iDrive system on eBay right now that is probably the same age as my brother-in-law's ~2001 system since it has the older style 5-button wide wall switches. I'm considering bidding on that unit but it's starting at $99 (!).
D
DIYorDIE
Well, I can't take credit for keeping these two units running without a hitch, going on 15 years now since they're my brother-in-law's. Plus, this is the first time I've ever touched them - and I ended up putting one out of commission. :lol_hitti
I'm just hoping to get it back to working condition. "First, do no harm."
Ilikeike
Northern Ca.
Thanks for reminding me of my idrive nightmare of 11 years ago.
I went through a couple of them before I damed them to hell.
The trash can is the only sure way to fix them. Good luck.
ssdave
Eastern Oregon
I've had two of the I-drive openers, and liked them really well. However, I stripped a gear on mine last winter, and had to replace it with a new belt drive. Was a royal PITA, as my garage was made around the i-drive, and came really close to not having enough headroom for the belt drive. Took me a couple of days of tinkering to make it work out.
Anyway, if you determine that the unit is indeed not working, I have a perfectly functional electronic package and motor, just has a stripped worm gear. Have the remotes, etc. too. Anybody needing spare parts, I'd consider selling it off; I've been meaning to list it on ebay but haven't had the time.
Of course, would trade for Williams or Proto tools.......
dave
D
DIYorDIE
ssdave - Can you look and tell me which model you have? My brother-in-law's openers are the "3661-372" (circa 2001) with the wide 5-button wireless wall switch. I might be inclined to think that the later "3663-372" models with the vertically-oriented wall switches might be backwards compatible, but since we're talking about Wayne Dalton iDrive openers, I wouldn't bet money on it.
From what I could see on eBay listings, the little car fob 2-button remotes look about the same for either model, but the wall switches definitely look different. That alone makes me wonder if they changed the remote transmitter and receiver characteristics on the later models (making them incompatible with my brother-iin-law's older car remotes and wall switches). Which style wall switches do you have?
As I mentioned in my original post, the two motors I have work fine - the problem seems to be in the circuit board not getting power to the motor plug, so your stripped worm gear doesn't matter to me. Why don't you PM me with the model of your unit and what you would take to part with it if I end up going that route? (Sorry, no Williams or Proto tools...) I think I would trust a Garage Journal person before I would an anonymous seller on eBay.... Thanks.
AlJ
I have two idrives that have worked fine since 2003. One just quit. The door is closed, but the opener is in the “up” position. With the emergency handle in the operating position, I have tried to lift the door manually, and as I raise it, the motor swings down and stops it. If I put the handle in the Manuel position, I can raise and lower the door and the motor does not move. I have adjusted the screw and the motor will not drop down, while the handle is in the operating position. When I press the button on the remote wall, mounted opener, the motor beeps, but there is no action. Any thoughts?
NUTTSGT
The opener is swinging down as an anti break in device like it should.
Been a few years since I had our I-drive openers. I believe there's a fuse inside that can blow, but don't hold me to it.
There's literally no parts available or factory service for these openers.
There comes a time when you bite the bullet and replace the opener. That is what I ended up doing.
AlJ
During normal operation, shouldn’t the motor be down when the door is closed?
NUTTSGT
Yes, it should flip down once the door is fully closed.
Like I said, it's been awhile. IIRC, when you pull the cable to put it in manual mode, the motor should flip up.
nadogail
Coronado, CA
This thread reminds me to appreciate the excellent Tech Assistance I have received on the Geni Openers in my rentals.
