Stupid stuff in the garage
rrudd2
Petersburg
Blue shop towel in my blowoff valve tube. Wouldnt make boost. Removed clamp/tubing and lol'd. I had left the rag in the blower tubing to prevent anything from getting in and assembled it without thinking about it.
Did something similar to my daughter's Dodge Neon when I had to replace the radiator. Stuffed a paper towel in the upper intake to make sure no debris got in there while I removed the radiator.
Forgot about it and put the car back together. The paper towel got sucked in and fouled everything up!
I still catch sh*t about that!
OccupantRJ
Eastern North Carolina
My teen daughter wanted me to build a bath cabinet with her for her bathroom yesterday, so I decided it would be good father/daughter time. Explaining processes as we prepared the wood when I measured the back, I cut it an inch too narrow on one side. When I placed on to the cabinet box and we both realized it, she simply looked at me and said " Measure twice, cut once?" I said "Yep!" We both got a good laugh out of that one.
dodgemike
I love that sizzling sound your
fingertips make while they are
turning white. And the delayed
reaction before you drop the part
you just welded. Thousand one,
thousand two. Aw @&%%*#.
Sent from my SCH-S720C using Tapatalk 2
Haveblue
kansas
^ Dummy! J/K! Here's mine.. Spent a little time getting the mower ready for the season. Got her wheels lubed, changed the oil, pulled the blade and took it to work to sharpen it. (I find any excuse I can to use my new 4 1/2" grinder :evil:) Well a few days went by before I put the blade back on... after three pulls.."Why Wont this thing start? Its always started easy!" Well some dummy pulled the plug wire when he pulled the blade, and forgot! :Homer: DOH!!
v7john
West Wales, UK.
Changed the brake pads on my old Citroen XM which has hydraulic suspension. Lowered the trolly jack under the front and the car settled right down so the jack wouldn't come out. No problem. Started the car and stood back watching the car rise up. It then ran off the jack, down the hill and into the hedge as the parking brake was off and I'd removed the chocks. In the process it managed to run over all four wheel trims which were laying on the ground. Got them all.
mmb617
PA
So many of these stories sound familiar. As I've reached the golden years I find that since my memory ***** I am able to recycle the same mistakes over and over.
My collection of potential contributions to this thread is vast so I'll just pick one off the top of my head. I have an engine on the stand and I am priming the oiling system by spinning the oil pump with a drill. I notice the drill isn't working very hard to spin the pump, probably because the oil is simply shooting out the uncapped hole for the oil pressure gauge. Tell ya what, it shoots out of there pretty far!
Cryptic1911
Willimantic, CT
I've had a few good ones.. I was installing some OEM euro led tail lights on my 2008 GTI, which requires a few wires to be run, and some coding changes on the ecu, and also replacing an intake pipe. So, I run my wires, connect them, hook up my laptop and make the coding changes, lights work great and all that. I go replace the rear intake pipe, since I had been sent a replacement after the finish got clouded up from the heat (they used the wrong clear on the first batch). I get it all buttoned up, and go to start the car, and it turns over and over, then barely catches, and will only idle at like 400rpm. It's running like ****, and won't take any throttle without stalling out. I take the intake back off, and it looks fine, but I toss my old one back on, and it's the same. I hook up my laptop and scan for codes with the vag-com software, and I see something about a pressure sensor error. I ask a guy online who is a VW tech, and he says that sensor is inside the ecu, and it isn't replaceable.. ****! I fried something in the ecu when I was goofing with the wiring!
I call and have the car towed to the dealer to have them look at it, since it isn't something I can fix, and I'll just have to pay and get it replaced. Well, they put it up on a lift, and one tech noticed the intercooler hose was collapsing when it was barely idling. They start popping things apart, and come to find out, there was a plastic bag inside that intake pipe that I replaced from when they packed it to ship out. I had looked, but it was like 3ft long and had bends at both ends, so I didn't see anything. It sucked the bag through the pipe, down into the compressor housing on my turbo, and was lodged about 1/4" from the compressor wheel. The tech pulled it out, and the car was 100% fine.
I felt like a real ******* paying that $150 bill at the dealer. LOL
I also had another really stupid one last weekend on the same car. I replaced the turbo with a larger one, did new plugs, coilpacks, etc etc. I had a hell of a time getting the downpipe and stuff off because the bolts are hard to get to, and were rusted pretty badly. I had to take the passenger wheel off, the inner wheel well cover, and the axle / ball joint so I could get enough room to get to the stuck bolts. I get it all done (after taking 3x as long as it should have because of the disassembly), and I pull out of the garage, and the car feels weird, like I have a lumpy tire. I go around the block, and it's really feeling odd, so I pull it back onto the lift at the house. I only took the passenger wheel, axle, and ball joint, so I go loosen and retighten all that again. I go back out, same thing.. driving really weird again. I pull back in, and my dad is like did you check the lug bolts? I said yeah, I only took this wheel off, and you saw me put it back on and torque it twice. He goes and checks the drivers side... ****** lug bolts are finger tight!
I think I just hit those lugs with the impact while I was over there, figuring I was taking all the wheels off to swap to my summers, and then forgot. I torqued those, and everything was great until I blew the intercooler hose off at 27lbs of boost hahahah
TAMPAGT07
Palm Harbor, Fl
This is why I always have a roll of blue painters tape handy when pulling stuff apart....Kinda hard to miss bright blue tape wrapped around holes... I never use rags for pluging up stuff...
katy
Many years ago I was helping one of my brothers replace the (steering) idler arm on a ,51 Mercury. Couldn't get the swivel nut loose, it was about 1&1/8" or 1&1/4" hex. Had an SK breaker bar on it and it wouldn't budge. Put about a 4' snipe (cheater pipe) on it and pulled and pulled until finally the breaker bar broke.
Took the bar down to the tool supply place for a warranty replacement. The guy behind the counter said he'd never seen a broken one before, did we hammer on it or use a cheater bar on it? No of course not, who us? We wouldn't do anything like that.
Took the new bar home and while getting ready to try again I looked at the new parts and found that the part that we were trying to remove was LEFT HAND thread. Uh oh.
DangerousDan55
Hockley, TeXas
A friend of mine told me this one. While camping she misplaced her cell phone. She was using a flashlight to look for the misplaced phone. Finally realized she was using a flashlight app on her phone as her flashlight.
sprntpshr
Southern Ontario
I am forever setting my glasses down to work on something only not to be able to "see" them to find them.
Maybe its just old man disease creeping in..
