jradtke920
- Joined
- Nov 30, 2023
- Messages
- 3
I am getting quotes to have a 48x56 garage built in northern WI. My original plan was to go with sono tubes and a wet set sturdi wall plus style bracket. Does anyone have experience with these and when it comes to pouring the slab do you just strike off the grade beam covering the top of the sono tube and the bracket hardware? I want something that is going to last which is why I didn't want to go with the traditional posts in the ground. Is this the route I should go or should I pour a slab with a footing first and screw brackets into the slab? Any advice is appreciated. Thanks
