I am getting ready to side my new garage with vinyl siding, and I want to put a layer of 1/2" styrofoam insulation on the wall before the siding to give a little extra insulation, and also for noise reduction. From everything I have read the styrofoam will act as a vapor barrier, so I am assuming when I insulate the inside of the garage I should use unfaced insulation so that any water vapor can escape to the inside of the garage? Also, on the 4x8 sheets for the outside, would the foil backed be any better then the standard blue or pink styrofoam? The R-value of that is slightly higher. Any tips would be greatly appreciated!
