duneslider
I'm planning to put a sub-panel in a utility room next to my garage but as I have been planning out the future I am wondering what is the proper way to do this based on some possibilities in the future.
Main power comes to the house on the south of house into the meter that has the 200amp disconnect/breaker then travels halfway through house to the 200amp panel in basement. I want to run a line from the house main panel to the utility roof near the garage on the North end of the house.
Future plans would include a potential shop with a possible ADU above the shop which would be located on the North side of house near the subpanel.
If I add solar in the future it would also be located towards the north end of the house nearest the potential subpanel.
If I add car charging, additional welder, rv hook ups these would also be near the subpanel (currently already have a 40amp/220v plug in the garage coming from the house panel).
If I add a battery wall this would also make the most sense to be on the north end of the house near the potential subpanel.
Initially, I had planned on the 90amp feed that is so often talked about on here to feed the subpanel but given all these future possibilities does that make sense, or should I be looking to run something larger to the subpanel given the future potential? It would be very difficult to change any of this wiring back to the house panel in the future once the basement is complete.
