I currently have a new 50 amp range outlet run from 6/3 Romex in the house. I'd like to also drop in a small lighting sub-panel on the wall behind this outlet but about 10 feet away.
Does anyone know if it is code-legal to T splice into the outlet feed in a junction box with a Polaris IPL 4-3 connector, and then feed the sub-panel from this same feed?
Is it NEC compliant to have an outlet and a sub-panel on the same cable run? Or do I need to splice a new cable extension, run it to the subpanel, and then run a new cable back to the original 50 amp outlet to be in code?
I can't for the life of me find it in the code and I've exhausted my google skills.
