Sub Panel Feed Wire Question
looking better. kinda pointless to have 2 ground bars on same side of panel. can you move the right ground bar over to the left side of the panel?
gpiggaz
Tucson, AZ & Edmonds, WA
I'm not an electrician, but I would probably just use one of the ground bars and forgo using both of them, I don't see any reason you'd need two in that sub panel.
Hopefully, your future plans don't call for more than 6 breakers- otherwise you'll need to add another means of disconnect ( another breaker between the feed and the power bus bars) to meet code.
Also, did you have any sort of Torque driver to set the torque on the screws? I would make sure I torqued the screws ( Breaker wires, Ground and Neutral) to the specs called out on both the panel and the breakers.
Nice job otherwise.
Nope he wont need to do that. This is in an attached garage.
Norcal
When I looked at the photo wondered if the tie bar had been removed between the bars mounted to the interior, I always cringe when that is done as it's rarely done right & defeats the purpose of having the convenience of a split neutral, being able to land the neutral on same side as where the hot is landed makes things easier, that feature first appeared in Gould/ITE (now Siemens) loadcenters in the late 1970's. If the electrician was using twin, or quad breakers, the neutral would line up below the load side of the circuit b
breaker, but I hate twins in new installations.
Edit: the OP will need a access panel to gain access to the misplaced LB if the drywall is replaced.
:D
P
ProjectX
Katy, Texas
I didn't add any ground bars and I'm only using one of them. The small one on the right came installed in the panel. I don't see myself adding any more than 2 more circuits in the future since this is my attached 2 car garage. Also I didn't torque the screws but I dd wiggle them and tighten them several times until they wouldn't budge anymore so they should definitely be good to go.
Norcal
Too much torque is as bad as too little, & it does sound like the tie bar was removed.
