ABusDriver
Hello Garage Electrical Guru's
I had a sub panel installed in my garage by a professional electrician at the same time my basement was finished a few years ago. The feeder cable from the main panel enters through the back of the sub panel. I've finally decided to finish my two-car attached garage and am starting on the wiring. The sub panel was flush mounted to the existing studs on the common wall with the house. That 2 x 4 wall is sheathed with 1/2" foil faced foam and 1/2" drywall. I thought it would be fairly easy to run the new wires down from above the trusses inside the stud bay and into the top of the panel. I failed to realize that the split entry construction has the upper level rim joist and sub floor just above where the panel was mounted as shown in the picture. I've shut off the sub panel breaker and removed the panel to assess the situation behind it. I would need to drill holes through the sole plate and sub floor of the upper level which would leave wires on the far side of the rim joist (in the unfinished utility room) then drill through what is the top plate (2 2x4's) and finally into the panel.
I think it would be easier to change from a flush mounted to a surface mounted panel and run the wires through a conduit and junction box above the trusses (or a 2x4 constructed chase) . I'm looking for suggestions as to whether that idea is feasible or another solution if I was to retain the flush mounted panel.
Thanks,
George
Thanks,
George
