ZRX1040
Edit: Found what I needed, Thx.
I'm not up on current Michigan residential codes. (separate ground and neutral buss and install ground rods at each buildings panel.)There are no NEC restrictions on the actual fact of running a subpanel from a subpanel. You just need to follow the proper installation requirements and overall load limitations.
