Hooking a sub panel up in garage. Running # 6 wire from house panel with double amp 60. The circles are where the red power, black power, white neutral and green ground should be connected, I think. Please confirm.
I don't think I need a ground rod to connect to in Ontario.
The neutral bar where I will connect the white wire is also grounded to the panel box itself. Is there risk of shock if I touch the panel box itself?
Thanks
Thanks
