My main panel is in the garage. There is a 240v circuit in the main panel running in conduit to what used to be a hot tub. The conduit ran inside the garage, then through the walls, then under the house, to outside the house to a cheap disconnect box.
I'm keeping the conduit inside the garage and pulled the rest of the cable inside the garage. The idea is that the 3/4" grey pvc conduit will terminate at a sub-panel, I'll be putting in. (I've noted all the warnings about not bonding neutral to ground bars in the sub-panel)
Within that subpanel, I'd like to have two 240v circuits. One that will run flex conduit to a hard wired compressor, the other to a 240v outlet for plugging in the drill press, or switching out to a welder, etc.
The current breaker in the main panel feeding this wire is 50A. The wire doesn't specify gauge, but if I had to guess it is 8/3wGrd (two hots, one neutral, one bare ground).
Is this wire thick enough to switch out the main panel breaker to 60A, and then have two 30A breakers at the subpanel or one 40A, one 20A? Or is 50A at the top of the wire's capacity?
For reference here are a couple pics of the existing setup, the 50a breaker, the conduit running along the inside wall of the garage, and a picture of the wire.
The hot conductors are 1/4" in diameter (this is including insulation) and have 7 strands of copper wire in each. The outer sheathing is black. I think that makes this 8/3 w/ground right? I don't want to buy and fish in new wire. Should I keep the 50A main breaker and just put 30a & 20a breakers in the subpanel? My air compressor wont be over 5hp (haven't bought it yet), and my drill press motor is 1.5hp with its own capacitors and can run on 125v if needed.
