matemike
Hello folks,
I plan on making a sub panel in my shop coming off one of my two main 150 amp each (300 total) panels. I am a total noob when it comes to making a sub panel, so I got a quote from an electrician to do it for $3500. Being a major DIY'er I'll just make my own cable run and call him for the final hook up to alleviate that absurd cost. I do have some electrical experience with wiring up fixtures and receptacles, but none with making a sub panel in a detached building. So that's where the electrician comes in, to make the hook-ups, I'll make the run and mount the new panel in the shop. Should be simple enough just running cold cable from point A to point B.
That being said I know I'll need to run a ground from the new sub panel to a ground rod.
Now the questions I have are so elementary that I can't even find answers on google.
First thing is that I'll only need 70 amp service out there; I would like 100 but not sure if it can be done off my 150 amp house panel. Suggestions?
Anyways, 70 amp panels are a rare find and the ones I found only have 2 spaces, 4 circuits. I'll need more than that. So could I just install a 100 amp panel having more spaces with 70 amp service going to it?
Weird thing is that 125 amp panels are cheaper than 100 amp panels; could I just use a 125 amp panel to get my power distribution in the shop whether it's 70 or 100 amp service?
What size wire do I need to get 70 amps? I figure I'll need #1 wire to get 100 amps as it is about a 250 ft run total going through the attic in the house and down the side then under a side walk and ultimately out to the shop. Everything will be in conduit.
Could I stick with the #1 wire size should I need to go with 70 amp power? I figure if it's rated for 100 amp it will carry 70 no problem.
Is it reasonable to try and pull 70 or even 100 amps off of the 150 amp main panel in my house?
I can certainly get pictures of everything later today as I'm sure those will help.
Thank you folks for all the assistance and dealing with a noob like me.
