Davey4000
I just completed a sub-panel installation in my new detached garage. I have a problem I cannot figure out. The sub-panel has power, but I cannot get any items to work off of it. I’ve tried a drill and lamp to no avail (both work in the house). Voltage at the sub-panel measures (with VOM) 121V from 1st hot to neutral, 2nd hot to neutral, circuit breakers to neutral, busses to neutral and 240V from hot to hot. Very consistent and expected.
I even wired one receptacle straight off of a breaker to see if I had a problem with my receptacle wiring. I measure 121V by sticking the probes of the VOM into the slots of the receptacle, but it still will not light up a lamp when plugged in. It will, however, light a receptacle tester. By the way it indicates it is wired correctly.
Here is a summary of my installation:
- 200A main panel in house
- Added 100A double pole CB to power garage
- Ran three #2 CU THWN with one #8 ground to a 100A disconnect on outside of garage
- Ran three #2 CU THWN with one #8 ground from the disconnect to the sub-panel in the garage
- Total conductor length = 45’
It just seems odd to me that you can measure the proper voltage at the proper places, but fixtures will not work. This is very perplexing. Has anyone ever heard of a similar situation or have any ideas?
