BlackKnight427
Hey guys I have a few questions for you that have either installed or have had a sub panel installed.
I guess my first question is how high of an amperage breaker would be recommended or how would I calculate for one? the garage is 22x24 it will have a pretty decent sized compressor (amperage rating on compressor is 22amps it has a 5hp motor) a tig welder, lift, fridge, and some lights maybe like 8 florescent fixtures along with some outlets I'm thinking 8-10 outlets.
The panel in the house says it only has 100 amp mains, so Im assuming I cant or shouldn't try for a sub panel that has too high of a rating.
I was told that I may be able to upgrade my panel in the house and get a higher amperage service in order to get more available amps out to the garage sub panel, Have any of you ever done something like that?
How involved was it and could you give me an idea of what something like that may run? I would just like a ball park, for example would it run a few hundred (2-300) to a few thousand (1500-3500)?
