New hot tub going in our mountain house. Trying to figure out how to get it wired...
Two problems with the existing sub-panel... First, although within 50' of the hot tub, not 'within sight'. Builder put panel is on second floor deck and d the hot tub is underneath it at ground level. Second, wired sub panel is BR type, and the GFCI breakers that came with the hot tub are CH type.
I'm considering a few options, but wondering about this one:
Can you do that?
Does NEC and/or good practice allow wiring a 'sub-sub' panel?
[I'm sure 200 people will feel compelled to say 'hire a licensed electrician', which I should and probably will do, but I'd like to know the answer to the question anyway...]
- Builder originally put in a 50A sub-panel specifically for hot tubs, but not in the right place. No breakers currently installed in it.
- Hot tub came with a 50A sub panel with 30A-220V-GFCI and 20A-110V-GFCI breakers and a 20' ultratite whip.
- Install a 50A non-GFCI breaker in the existing above deck sub-panel.
- Off that 50A breaker, run four 8AWG (hot, hot, neutral, ground) in flextite to feed second hot tub specific sub panel.
- Use the new second panel GFCI circuits to power hot tub through whip.
Can you do that?
