Submerging Ratchetsi
LOW1
ontario
In our docks and boathouse there are some galvanized nuts and bolts. Some of these are below the waterline. Occasionally these nuts need to be tightened or removed and a ratchet and socket makes this easier. How much damage will I do to my ratchets If I briefly use them under water? They are basic craftsman ratchets so of no real value but I also don’t want to destroy them. Should I buy a used “junker” ratchet or breaker bar at Restore to use? Should I just use a wrench?
Gangly
The Woodlands, Texas
Ratchets will be fine as long as you clean them out with something that will displace the water, and lube/oil them immediately after use. if I had to use a wrench, I'd use one without a ratcheting mechanism, such a a breaker bar, and just dry it then dip it in oil afterwards.
Personally, I would use an open-end or box-end wrench then dry them off real well before wiping them down with an oil rag.
Just curious, but why not just use an open-end or box-end wrench so you don't have to worry about anything other than drying it off? Too slow?
Mr Ratchet
For this kind of work, I only use wrenches (combination). It's a little slower to tighten/loosen the fasteners. Quicker over all since a good dry off and maybe a spray of WD-40 is all that is needed. Putting tools with moving parts under water is a sure way to have them lock up from rust build up. You would need to take the tool apart to dry and spray with WD-40.
I also make a lanyard out of nylon string for the wrench/s. Make a loop around the shank of the wrench. Make it big enough to slide back and forth. Not too big to slide past the open and box end. Then make another loop that goes over your wrist. This will keep you from looking for a dropped wrench. I know this from experience!
Gutman
ENC
And a big magnet on a lanyard for dropped hardware. I know this from experience.
I also use combination wrench or socket and breaker bar. I tried the ratchet but as stated by others, the post-use maintenance time took longer than the use time.
I'm currently waiting on lower water levels so I can use an angle grinder to flush cut some old, rusty bolt ends from old brackets.
L
LOW1
ontario
Ratchets will be fine as long as you clean them out with something that will displace the water, and lube/oil them immediately after use. I would use a wrench without a ratcheting mechanism, such a a breaker bar, and just dry it then dip it in oil afterwards.
Yes. Up until this summer the dockwork only involved an occasional tightening that only took a minute or two with an old already-rusty channel lock. But now I’m building a staircase and would prefer to use a ratchet.
AEAdam
SE PA
I wonder if you used a relatively open ratchet like a craftsman raised panel POS, then after having been submerged, you put it in a can of motor oil. if that would be okay. Are we talking about salt water or fresh water?
drokihazan
the above ratcheting wrenches are a nice idea. Just get one of the old style Snap-on ones off eBay for like $20, dedicate it to this job, and when you get done give it a nice spraydown of WD-40 and then throw it in the used oil can for a day. Seems like a combination wrench and a ratcheting wrench is probably enough to make your life easier, and a lot easier to clean too.
Beerhippie
Far NE Oregon
Obviously, the only GJ-correct answer is this:
Good to 50 meters!
Ohio Andy
Columbus, Ohio
Good to 50 meters!
Ignore for a moment that of course you want one....
I can throw away a lot of ratchets before I get to $1,800 though.
KnurledNut
n/a
I’ve worked with utility crews installing water line repair coupling clamps on pressurized lines. This is often underwater in a pit full of muddy water and high pressure water spraying. I keep this Wright open head ratchet in my kit for uses like this and other sanitary applications:
https://www.harryepstein.com/products/1-2-dr-ratchet-open-head-10-1-2-series-80?
It’s simple to disassemble for drying and cleaning, but is usually not necessary.
PCustoms
VT
Good to 50 meters!
How about a Ryobi and a hefty bag?
AEAdam
SE PA
One question about the title of this thread: is ”Ratchetsi” Italian for ratchets? Are stubby ratchets “ratchetsini” in Italian? Or is it the Italian reflexive, to ratchet oneself?
woody 73
The Great State Up North
I've picked up old rusty ratchets and brought them back from the dead with a very good cleaning, ones that people gave away because they were stone cold dead after all the abuse. Water for a few hours is nothing provided you take it apart that same day. clean up all the internals really good and lube it up.
I would prefer myself not to drop it in any water, but it's not the end of the world, just take it apert and clean everything up.
Ohio Andy
Columbus, Ohio
Wright has an open pear ratchet, perfect for the job.
Yes, its not what you asked.
I am simply enabling your tool buying habit.
I really like their tools and when I saw that one I remember wondering the typical use case. I could not service of it was for ear of cleaning, but I thought you would need to clean it a bunch and it might become unusable from things like sand in the gears.
I should probably just Google it. Never occurred to me that I could use it underwater then just spray it down.
rust in the eye
Chicagoland
Seems to this guy it might make sense to soak the ratchet in light oil before use. After use again in oil positioned so the heavier water could flow out/down.
Leaflessshadetree
Don't ask.
I have an old ratchet that I use underwater for driving a handfull of lagbolts just about every year. I usually let it dry out in the sun then spray/wipe it down with penetrating oil.
Etchase
Hawaii
Thorsen and P&C made a bunch of those open gear ratchets for decades. They are plentiful and cheap and almost always in good shape because they are so easy to clean. Wright carried on I suspect to supply the military. Nothing better in a bad environment than a ratchet you can clean with a dip in a can of oil. Sand you can just blow out. Sealed heads usually aren’t.
alinc100
Dearborn,MI
HF has a composite body ratchet, though you'd still have to lube/dry the internals. Old ratchet wrenches are a dime a dozen and the open gear ratchets mentioned above are plentiful.
Wrench-Polisher
DEEP in the rusty rust of rust belt
Military field repairs, basically 100% guarantee that they will be getting daily mud baths.
Anything on a tracked vehicle will be enclosed in mud, they will probably use the handle to chip the mud away from the bolt and go to town.
Jgaz
How far below the surface of the water are the fasteners you are dealing with?
40 years ago I needed to do some work on a friend‘s boat hoist. The fasteners were 24 to 30“ below the surface of the water and quite rusty. Did I mention the water was cold?
I used a 1/2” drive air gun powered by a portable compressor, a long extension, and the appropriate swivel socket on the bolt head with a box wrench on the nut.
Worked like a charm!
L
LOW1
ontario
Anywhere from one to 30 inches
