smokey_truck
- Joined
- Sep 26, 2011
- Messages
- 29
Folks
I have 100 AMP feed from my main panel through a breaker to my detached garage, I am using XXHW- AWG-2 wire. It has 2 hots (black) and one bug spirled aluminimum wire. 2 hots are connected to the breaker poles and spirled wire is connected to ground from the main panel and now on the other side I have 100 AMP subpanel.
The wierdest problem is
My ground connections:
when I connect all the big Aluminium ground to the ground lug on the ground bar and all the copper wires from the electrical circuit is connected and the ground bar is bonded by the strap to the green screw on the case
The neutral bar has all the neutrals connected to the neutral bus
I have no power and only on GFI outlet I can see the power but when I put the 3 tester it says Ground/hot reversed.
My electrician connected before all the neutrals to the bonded side and ground to the unbonded bus bar. I have all the power and the 3 tester checks out fine.
What seems to be the issue here I have no idea. Can anyone shed some light on this please.
