Cruzan80
What is there to fail on? It is clear they don't know any of the codes!Personally I would not open that can of worms.
You want to get failed on all the things?
This is how you get failed on all the things.
not true. not true at all. an inspector cant just fail you on stuff that is up to code because he is mad. That isnt how this works at all.Personally I would not open that can of worms.
GC should pay the electrician to install the ground rods ot notified the framing crew of what that rod was for and to not cut it off.
Well yeah. Maybe i should have chose different words.not true. not true at all. an inspector cant just fail you on stuff that is up to code because he is mad. That isnt how this works at all.
with an install like this, I would welcome the inspectors nit-picking. the Cont did a real **** job.... the more nit-picking the betterWell yeah. Maybe i should have chose different words.
He can be extremely nit picking. Can make it difficult for you.
should be there now. had to reduce the size so it would upload. my phone produces pics too large to upload here directly.Picture?
Lower right hole needs a clamp of some formshould be there now. had to reduce the size so it would upload. my phone produces pics too large to upload here directly.
Yeah, the black wire in that hole is the grounding rod connection that he installed. He didn't put in a bushing for some reason. I put the building bonding wire (bare copper) through the same hole but I didn't have a bushing or I would have installed one. None of the Romex has clamps on the pass throughs. Only bushings. I will put that on my to fix list.Lower right hole needs a clamp of some form
Plastic fittings on top/bottom need chafe bushings
The entire state of Indiana is on 2008.that would be crazy if theyre still on 1999 code cycle. i call BS
that is your opinion. If the city inspectors (two of them actually) and the electrician tell me it was not only not required but undesirable, they win over opinions here. I have read the NEC on it.Both of them need to read the NEC.
There is no exception for "low lightning" areas.
What is their definition of significant lightning?
What happens when you do get a lightning hit in your low lightning area?
What is the hazard created?
My understanding is that if you are in a place with lightning you need grounding rods on the outbuilding subpanel. If you are in a place where there is little lightning then you do not. I added grounding rods to a shed here in Norcal because several people here flamed me for not having them for a shed subpanel. Then when the building inspector came out for something else electrical he saw them and said, "you really didn't need to do that here. Why did you do it? It is only a requirement where there is significant lightning. In fact we wish you had not done that. You created more of a hazard by adding them. We don't get lightning here except rarely. I should make you take them out." My licensed electrician told me the same. The moral is, find out what your local codes require. In Texas you get lightning so I would suspect you need good grounding rods. Use a strong rotating hammer drill to drive them in.
Don't start this again. The NEC requires a grounding electrode for separate structures with a feeder, no exceptions. Just because the AHJ chooses to not enforce things, it's still in the book. For many years our inspectors chose to not enforce the GFCI requirement for sump pumps even though the NEC clearly stated it was required.that is your opinion. If the city inspectors (two of them actually) and the electrician tell me it was not only not required but undesirable, they win over opinions here. I have read the NEC on it.
this is totally 100% incorrect. nowhere in the NEC does it say electrodes are only required on a detached subpanel if there is lightning in the area.My understanding is that if you are in a place with lightning you need grounding rods on the outbuilding subpanel. If you are in a place where there is little lightning then you do not.
wrong wrong wrong. the inspector cant just make up rules as they go. unless the AHJ (which he is not) has a WRITTEN amendment, then the electrodes ARE required by the NEC.that is your opinion. If the city inspectors (two of them actually) and the electrician tell me it was not only not required but undesirable, they win over opinions here. I have read the NEC on it.
The shed is 4' from the main house and main building panel. The main panel has grounding into the foundation, rebar and a rod at that point.
They said that the code in the NEC is there specifically to protect the outbuilding against a lightning strike,
and that by adding the two new rods right adjacent to the panel at the shed, it is making it more probably that in a nearby strike, my main panel will get hit either from the shed or the panel itself.
They were also concerned that some of the current in a strike nearby might flow the 4' from my house into the shed and down to the grounding rods, creating additional issues than if the main grounding of the panel was not so close to the shed grounds. They were well aware of the NEC when we discussed it because their comments caught me off guard.
id love to know what hazard he was referring to. because none exists by simply adding grounding electrodes.
