Success Removing Tire Marks From New Slab
gmagno
I was pretty pissed that the builder justified the tire marks on my new 40X60 slab as my responsibility to clean. I searched the internet and these forums for a solution and found most people shared my frustration as this is very common. Still pissed but made a cocktail that works.
2 gallons water and 1 gallon muriatic acid in a 5 gallon bucket. Doesn't matter if the floor is dry or wet, same result. It takes the top layer off and you are left with a clean, dry and barely coarse finish. Staining mine but you could seal the finished product after rinsing it once more to remove the sandy residue.
Here is a short video to show how simple it was.
Keep in mind this will take you 8 hours start to finish on a 40X60. I hope this helps those like me who weren't sure how to remove the tire marks. I will post the finished stain results in my gallery thread.
Nighttrain
Dripping Springs, Tx
Did you need to put a base on it afterwards to neutralize it? I have the same size shop and need to get something on the floor, looking at a acid statin then a top clear sealer.
G
gmagno
The initial "etch" before stain is with muriatic acid and you neutralize it by rinsing thoroughly with water.
This is the basic idea for stain
. They are using baking soda and water to neutralize the stain but I purchased the items below from Home Depot. Subscribe to my gallery and you can watch me do it. This way if I screw up you can learn from my mistakes. First time for me.
1 gal. Rustic Concrete Acid Stain
Model # 203012900
$56.97 12 $683.64
5 gal. Gloss Coat Clear Wet Look Solvent-Based Acrylic Concrete Sealer
Model # 203075969
$94.97 6 $569.82
1 gal. Cleaner Degreaser and Neutralizer for Concrete in 4:1 Concentrate
Model # 202272986
$19.43 4 $77.72
