Successful off grid lighting?
Brachunky
Derbyshire,England
Hello all!
I have a simple 8x17ft lock up garage (a few streets away from my house) here in England with no access to electricity at all and no way of installing a supply. For my basic hand power tools I use a small generator which works well. I only use the garage to maintain my cherokee so dont spend endless hours fabricating things like many of you guys do! I'd like to hear from anyone who has a successful off grid lighting system using solar bearing in mind my garage is really small. At the moment there are a few MR16 5.5w led lights powered by a 110amp hr leisure(marine) battery which gets taken home for recharging which is tolerable as I dont use the lights everyday.Having said that, a more permanent solar setup would be better.
Random Guy
Are you wanting to be able to work in the garage with the solar setup, or do you just want lower level "walk through" lighting?
HOTFR8
Castlemaine, Victoria. The Hot Rod Centre of Austr
Two small Solar panels with an inverter set up to charge a deep cycle battery would be all you need. I have a system here that charges from two 80 watt panels charging two 6 volt batteries. This system runs the office, computer, phone, answer machine as well as a couple of lights. It also trickle charges via a battery tender from the mains.
Given what you want to do a similar type designed system would work well.
kd3pc
Northern Neck
I have a single 120 watt panel, two marine batteries and a controller that I use to run several LED lights. All are "marine" LEDs with regulators, and provide a great deal of light. They are fairly affordable on eBay or a local chandlery. Good connections are a must, the panel keeps things charged and I get several hours of casual use before I need to wait for a day light recharge.
Keep an eye on the batteries, and best of luck
2ManyProjects
Hello all!
Most of the same questions I asked when you posted essentially the same query in the other thread still apply. The one question you did partially answer this time ("...and no way of installing a supply") leads to another obvious one: WHY NOT? The "a few streets away from my house" notation strongly implies that this is NOT a "middle of nowhere" wilderness/far-rural situation, where utility power simply isn't available. So what EXACTLY is stopping you from installing normal electrical service?
If perhaps it is because you rent that garage rather than owning it, you will presumably face much the same dilemma to install any sort of solar system: As a permanent modification to the building, it would at the least require owner approval; and it MAY require building permits, the approval of any local zoning board or "homeowners association" which may have jurisdiction, etc.
OTOH, if it is simply a (perceived) cost issue, you are near-certainly barking up the wrong tree: A properly designed and installed solar energy system capable of powering more than the equivalent of a couple of flashlights will surely cost MORE than whatever your local PoCo wants to drop a line and put in a meter.
If you're going to bother with a PV Solar system at all, you might as well size it adequately to power EVERYTHING, including those handheld power tools. The incremental cost to increase capacity pales by comparison to the cost of initially "buying in" to solar in the first place (i.e., the battery bank and its associated support structure, the charge controller, the inverter, the distribution panel & wiring, the various site-prep & installation costs, etc.).
You also need to keep your local climate in mind, particularly when sizing the panel array itself. Don't believe for even an instant those "Max. Output" claims made by the panel manufacturers. Those are theoretical "best case" figures, derived under ideal conditions (such as Summer in the Arizona desert, with full blazing sun 15 or more hours per day, and absolutely perfect panel orientation relative to the Sun). In real life, with a typical installation, you'll be lucky to average even half that; and that's before you even start to consider such things as the fact that you can't make significant power when its dark, or raining, or there's a load of snow on the roof.
Define "a few". Per the specs for something similar I was able to dig up quickly:
http://www.1000bulbs.com/product/63066/LED-MR64040G53.html
...each of those bulbs puts out MAYBE 300 lumens. So it would take well more than "a few" of those to provide adequate lighting even in a relatively small garage such as yours. Quick "back of the envelope" calculation: 8' x 17' = 136 ft.^2; 136 ft.^2 x 50 lumens/ft.^2 (a relatively minimal level of illumination; twice that is generally considered "normal" for garages & shops) = 6,800 lumens; 6,800 lumens / 300 lumens/bulb = 22.6 bulbs -- and that's before we consider the losses at working height vs. "source lumens"!
Frankly, to really properly light that space would likely require at least 50 of those bulbs. And at ~0.5A each (@ 12VDC), that's a 25-amp draw on the battery bank -- far from trivial!
Far more important than "not every day" is "how many hours per day"; and this needs to be approached on a "worst case" basis. IOW, you need to figure out the LONGEST period of time you could possibly be in the garage working on something, and need power. This will help establish the maximum daily "draw" that the battery bank must be able to supply without excessively discharging it (which can and will radically shorten battery life).
Perhaps so; but you really aren't "there" yet. Please understand that I am NOT arguing against Solar, per se; but it is vitally important to approach such a project realistically, and to NOT underestimate what will be required in order to avoid disappointment later.
I seriously doubt that.
You'll pardon me if I remain skeptical. The 'phone and answering machine are relatively trivial in terms of electrical draw. But even a smallish desktop computer with a flat-panel LCD monitor will consume something in the neighborhood of 100+ watts, even when it's not working all that hard. That figure could easily be several times that if it is a high-performance model or has a particularly large display; and Ghod help you if you have a laser printer. "Office lighting" can often be rather subdued; but you're probably still looking at another 50-100 watts there, at minimum. Throw in a few misc. odds & ends, and allow a modest "fudge factor" to cover intangibles and (especially) inverter inefficiencies, and you're probably looking at 250-300 watts total draw, maybe more. Let's be conservative and say 240 watts. That means that even IF those "80-watt" panels really do consistently put out that much power (which they near-certainly don't), you'd need at least three hours of direct bright sunlight for every two hours you spend in the office, and you have no "safety margin" to cover the occasional extended stay or night-time work session.
You mentioned that your battery bank is ALSO charged off the mains power. I would wager that more of the power you use every day is actually coming from that source, than from the solar panels.
Unless you are really looking for a "project", just keep doing what you are doing !
Buy a "regular" (non-trickle) battery charger for the shop, so that when you are there you can charge the battery off of the generator.
rsanter
visalia ca
If it was me and I wanted to,do,it the easiest way I would look,at the 12v LED lights like,used with RVs. Then you do not need an inverter to feed them. You can also collect more used car batteries when you can find them to add capacity to the system
Bob
Brachunky
Derbyshire,England
Thanks for the response's guys, both the simple layouts and 2manyprojects with that indepth answer! All the lighting has to do is provide some reasonable illumination whilst doing odd jobs either on the truck or at the bench.The garage itself is part of a cluster of units rented out by the local authority with none of them supplied with electricity. Apart from small jobs using the generator on occassion, if I have a power hungry task , this could be done at home. The suggestion about going the whole hog with a complete solar installation is not want Im aiming for hence the threads title-Its about lighting! I would be using the garage for a maximum of 10 hours a week or about 1.5hrs a day so ideas's around a simple panel/controller and battery system is the goal. Using the MR16 light may not be the best option but its been my starting point!
Jagmandave
Overland Park, Ks.
Why spend the money when you already have the solution in hand, just use the genset!
I would bet the amount you spend for petrol is far less than you'd spend to build a solar setup.
felixgogo
Hong Kong / England
Fully understanding the UK 'lock up garage' a few streets away situation and the fact that getting mains power in there is not probably practical I do agree that a limited solar system would be a good option to prevent lugging the battery back and forth, or running a noisy genset in a small garage.
A few years ago I kept my Caterham Seven in a similar rented lock up, and I wanted to run a Carcoon in there and used your battery solution, swapping a pair of leisure batteries over every week. That soon got old I can tell you! The garage belonged to someone else, and running in mains power with a seperate feed from the power company would be too expensive, and that was then back in 1996.
I had a similar situation with a shed recently across my yard, and I tried a solar setup up for internal lights and a led security flood.
I choose a system from 'The Solar Centre', and using a old battery, this system has a charge controller, and runs the 3 lamps in the shed and the flood with ease.
Check this UK supplier out - really good.
http://www.thesolarcentre.co.uk/
Cheers
Ian
david594
If your budget allows I'd recommend a setup with an RV inverter/charger like this:
http://www.xantrex.com/power-products/inverter-chargers/freedom-458.aspx
It has an AC input and output, and then connects to your battery bank. It will run the inverter off the battery bank, and when their is an AC source(running the generator) it will recharge the batteries. You could then wire up a charger to the battery bank to keep it charged and minimize the use of the generator.
I used this exact setup during an 8 day power outage last summer. During the day I'd run a small generator to charge the batteries, and overnight it would run a fan/light until morning.
2ManyProjects
In which case, we're right back to the problem of needing "owner approval" to make any modifications to the building. I am not familiar with how the various UK laws and customs on this front might differ from those in the USA, but I still can't imagine that this "local authority" would permit you to install such a system on an "ad hoc" basis. At the very least, there would surely be a small mountain of bureaucratic B.S. to surmount.
Understood. But my point was, even a "lighting only" system would still require at least some "permanent" installation -- which at this stage appears to be your main stumbling block, due to the rented nature of the garage. And if indeed you can (legally) install enough solar panels to power a decent amount of lighting, then there is little or nothing stopping you from installing enough to power at least your various hand tools as well, thus enabling you to (at least mostly) ditch the generator.
The battery bank and the controller/inverter are the least of the issues, as they are (or at least "can be set up as") "portable" devices (i.e., NOT permanently installed); and more importantly, they're inside the garage, out of sight. It's the solar panels themselves which are the problem. For them to be usefully effective, they're going to have to be permanently installed (presumably on the roof), at the correct bearing & azimuth relative to the sun, etc.; and THAT is where I expect you to have a problem.
That is a separate issue, really. Even if the MR16 types are "non-ideal" in some ways (and given their typical "spotlight/floodlight" configurations, they surely aren't), they at least have the advantage of being available in 12VDC form, which makes running them off a battery far more efficient (read: feasible) than having to use an inverter to power 120VAC lighting. But the larger point is, lumens are lumens, and NO form of lighting yet devised can reliably produce more than roughly 100 lumens per watt of input power (the MR16s I found do roughly half that). Regardless of any other considerations, you still need a certain number of lumens to adequately light up your garage; and that in turn means a certain number of watts will be needed to power them. My earlier estimate of 50+ 6-watt MR16s may have been a bit generous. But by the same token, you are NOT going to get away with a half-dozen of them either: You might as well mount a flashlight to a head strap, and pretend you're a miner -- your garage will certainly be dark enough to make you feel you're deep in a cave!
Seriously, by far THE biggest and first thing you need to deal with is to determine what you are and are not allowed to do with respect to making "modifications" to that rented building, and in particular what it will take (in terms of bureaucratic hoop-jumping) to enable you to install some number of solar panels on the roof. Everything else is but a distant secondary concern (and mostly irrelevant anyway) until you solve that problem.
Perhaps so; but cost is by no means the only issue. Portable generators are a PITA to live with, in several ways. Yes, they can be a godsend when they're really needed and there is no other feasible alternative; but if you can avoid the need, so much the better.
In principle (or at least "potentially"), I agree with you. But the big issue is that ANY solar system, no matter how limited to "lighting only" it may be, will require at least some degree of permanent installation (specifically, the panels on the roof). How can that not bring with it the issue of needing the building owner's approval, etc.?
Sweet! In a former lifetime, I had a 1967 Elan S/E. I had a LOT of fun with that car.
TractorJeff
Elkhorn, WI
I assume that there is no daily commuter car at your house?
If there was, then I would just pull to the doors, then run my alligator clipped wire out to the car battery.
Only other comment I can add is that my brother put two solar panels on the roof of his RV.
He has camped "off-grid" successfully a couple of different times/places and weather conditions. In my opinion, it can be done, maybe not optimum for everyday use, but in your scenerio where you are not there all day, every day.
I would think it would work....
kbs2244
No need to re-invent the wheel.
You can get complete solar/battery/LED lighting systems at the local home improvement place.
Most will have motion detectors and be called “security lights” but you can bypass that if you like.
2ManyProjects
How exactly would that work, given that the lights need to be inside the garage, and the solar panels need to be outside (and properly aimed, etc.; which brings us right back to the "bureaucratic" issues noted above)?
Further, the battery on any such self-contained system will necessarily be so small that it could not possibly provide a decent amount of light for any significant period of time.
6768rogues
Western NY
How far out in the country do you live? Your post says your garage is a few streets away, implying a residential area. I live in a somewhat rural area and there is electricity available anywhere. Solar can work but you have to mount panels, maintain batteries, etc. I would rather use a small generator with real lights.
Brachunky
Derbyshire,England
Well I have found a workable solution for now. Ended up with a pair of 10w cree floodlights above the bench powered by the 110amp leisure battery which so far is doing very well. This is for when Im spending a short time in there. Then 4 x 10w floodlights but 230v (this is the UK!) which are operated from the cars battery via a 500w inverter for when Im spending longer periods there. Due to the amount of shade, I will be taking note over the forthcoming spring/summer before fitting a solar panel.
Not perfect but so far working well:thumbup:
