Suggest a router
gtivr4
Vermont
So I am in the market for a new router. I want a good tool that will last me a long time, although it will likely only get ocassional use.
Budget: MAX $250, under $200 would be best
I plan on being able to both mount it in a workbench I have with a homemade fence, and also would like to have a plunge base. So a fixed base with the ability to adjust height from above would be very useful along with a way to remotely switch it on/off.
So far I've been looking at Bosch, DeWalt and Porter Cable, but frankly there are so many models just between those three that its confusing to a newbie.
KenC
oklahoma
The old PC model 690 in one of the kits with both bases is hard to beat. That is if 1 1/2 HP is enough for your needs.
G
gtivr4
Vermont
I'm thinking I'd rather have a more powerful router just for future proofing purposes.
rlitman
Long Island
Bigger routers aren't as easy to hand hold.
Whatever you get, I suggest finding something with variable speed and a soft start.
For most of what I do, my Bosch Colt is plenty (but that's neither plunge, or big enough to table mount). But I've got access to my father's 1/2" monster routers for when I need something bigger.
buick215
florida
I am not a router expert but I generally prefer the Bosch, Makita, and Porter Cable the most. The best is the Festool but their prices are always insane and out of line with the market.
robarosa
East Texas
I have more routers than I need. Just picked them up cause they looked pretty. Couple things I can say.
Get something around 2-1/4 HP
Get variable speed.
Get soft start.
Get router able to use 1/2" shank bits.
Get the fixed and plunge base set.
Sears are (or use to be) Porter Cable 892 (for the one I own.). Both are great. The one Sears sells with their name on it has a non-standard base. Base accessories must come from Sears. If that isn't important you can save some $ going that way. Look for the kit.
I like the Freud, but don't think they are made anymore.
I would pick one of these.
Bosch 1617EVSPK
Porter Cable 892 with both bases.
If you like to read got to woodrouterreview.com
Good luck.
KenC
oklahoma
Well, if you want big and would like a new 13 year old router, send me a PM. I have a Freud FT2000 that I bought new in 1998 and have never used. planned to put it in a table but wound up with a small shaper instead.
rallenc
Southern New Jersey
Keep your eye out for a Porter Cable, I believe, 7538. 3.25 HP, soft start, plunge base. Real Beast.
Somebody had one in the classified 6-9 mos ago that if I recall he wound up selling for less than $150. Most people with one of these probably also have a 690 that is probably their do to router. With a little patience you can probably find one in very good condition.
Also, the older ones were USA made...
srmofo
SW ohio
I believe this is my router . I picked it up last year at woodcraft or rockler for $200. The thing is a beast, I had originally planned on putting it under a table, but that just hasnt happened yet. Im also in the market for a smaller more manageable router when I just need to nip something off real quick
muibubbles
nj
a bit off topic but seems like a lot of you recommend porter cable... i thought the were a low end company of another brand?
i have a basic ryobi that ive used maybe once or twice, its not a common tool for me. i never really liked to handle it as its kinda awkward and one of the scarier tools for me. Idk your needs but at work i use a rigid trim router and LOVE the comfort of it. if your looking for a hand held one, the rigid one is nice and is 100 at homedepot and comes with a free sander (online only)
JimDon
MuiBubbles,
You're actually right and wrong kinda at the same time. Porter Cable, at least as I most recently read, is under the ownership of the Black & Decker Empire, therefore qualifying P-C as a piece of cr-p. Porter Cable used to be a stand alone co. back in the early 90s, and they were a hell of a good tool company then. Pro woodworkers idolized P-C stuff, especially their cordless drills and their routers. They just made a real solid tool aimed at the pro market. And actually, back in the 1950s and 1960s, B&D made some real quality power tools, including some 1/2 inch drills and Wildcat 9-inch angle grinders which can still out perform some of the stuff made today.
Cheers,
JimDon
rallenc
Southern New Jersey
MuiBubbles,
Cheers,
JimDon
Can't agree more. First thing you look for on a Porter Cable tool is COO. If not US made, pass....
Kenwc
If you want a hog, get the Milwaukee 3-1/2 hp Variable Speed. Love mine but it's mounted in a table.
Punkinhead
It's counterintuitive, but when hand routing heavier is better. A bit catching or a motor spinning up is less likely to move a heavy router. I have a Bosch 1617 mounted in a table and a 3 hp Dewalt plunge router I use by hand. Even the little 1617 will swing the large cope & stick bits for cabinet doors. Both have routed hundreds, if not thousands, of linear feet and keep going. The 1617 with interchangeable bases would be perfect if you're only going to own one.
yost69
WV
I have the hitachi KM12VC. Picked it up at lowes i think, a couple years ago. Have used it alot and still holds strong.
It has the soft start, variable speed, comes with a fixed base and a plunge base, and takes 1/2" and 1/4" bits.
I think its like $150 maybe cheaper.
I have a craftsman that stays in the table that was just under $100 and I have no complaints with it either.
I dont care what anyone says I think Hitachi tools are great. Of course I don't buy the cheapest ones, maybe thats why.
boiler7904
NW IN
I've got a Bosch 1617EVSPK that came with a 2 1/4 horse motor, fixed base, and plunge base. I keep the fixed based mounted to a Woodpeckers router table insert and use the plunge base for hand work. Bosch recently came out with an update to the 1617 that seems like it may be a better unit. I got a Bosch Colt a couple of months ago and almost like it more than the bigger one.
msnow
Another vote for the PC set as well and you can probably find one used on ebay or clist. The new bosch routers are nice but nothing cuts like the festool. Festool is expensive but you only have to buy it once and if you are making money off something their tools seem to quickly pay for themselves.
