bowlofturtle
I recently encountered a seized rear shock bushing. I pretty much destroyed most of it. So now i need to drive it out and install a new one.
Parts should be in mid-week and i need this done by the weekend.
So this is what i'm dealing with. The bolt that holds my shock to my rear spindle. You can see its a rubber bushing, the bolt goes thru completely and there is a fixed nut on the other end that is weld to the shock. This is a Nissan 350z, bolt head is a 17mm. Rubber bushing with metal collar.
What happens is the metal collar seizes to the bolt. So when i turn the bolt, the bushing is spinning as well. I had my IR impact at it full blast, used all the oils i can.
On this picture its on the right hand corner, that top bushing where the shock goes thru.
The whole thing is about a 1.5-2.25 in diameter.
I got a new bolt and bushing on order, so i'm thinking mini-torch off everything. Either cut-off wheel that bolt or so something to make it come off. I can figure that out. How do i drive the outer metal sleeve of the bushing and install the new one.
http://www.amazon.com/dp/B004FEJG66/?tag=atomicindus08-20
I can rent this from autozone. Not sure if it will work
http://www.harborfreight.com/four-wheel-drive-ball-joint-service-kit-4065.html
or
http://www.harborfreight.com/3-in-1-ball-joint-u-joint-c-frame-press-service-kit-38335.html
Never used this item, dont know how to use them but someone said they could work.
I was told to torch off all the rubber, hacksaw the inner metal sleeve and drive it out with a chisel. Then hammer it in, i looked and think i can use my 24mm c-man impact socket to drive it in as the diameter is really close, its not as big but VERY close. Maybe drive that out and in with a air hammer.
Please let me know guys.
edit:
maybe this but i think i will lack room to drive it thru.
http://www.harborfreight.com/10-piece-bearing-race-and-seal-driver-set-95853.html
or
edit:
no torch tho, will go to home depot for that one.
