Suggestions for Replacement Mesh WiFi Router System
kbuhagiar
Escondido, CA
Hello folks,
I'm fed up with my three-year-old Google Nest AC2200 Wifi mesh system. I have four nodes spread throughout the house, and one or more of them will drop out for a few minutes, or a few hours, on a daily basis. I'm convinced that it has something to do with flawed hardware/software updates pushed through from the Nest mothership, as sometimes the network will run flawlessly for a few weeks. And then - boom - back to the daily outages. My research online indicates that this is a common complaint with this generation of Nest mesh routers.
I'd like to hear from other mesh Wifi users about their experiences, pros/cons, and hopefully come up with a recommendation on not necessarily the latest and greatest but the most dependable system available.
Thanks in advance!
larry4406
Northern Virginia
Our Orbi 750 system has been rock solid since I deployed it during Covid.
I have a RBR750 router and 3 RBS750 satellites.
These are “old” and Orbi has newer offerings.
I would like to get a RBR850 router to take advantage of its higher speeds.
If I had to replace the system, I would still look into the Orbi.
dcg9381
Austin, TX
I use Unifi. Probably a little more expensive and a little more "power user", but I bought the whole ecosystem (network and cameras). If you really want to go nuts you can dive into any piece of the system via SSH and diagnose things.
Unifi has a super UI, I consider it to be the "iphone" of mesh wifi... For residential, you start with a Dream Router 7 ($300) and then can add mesh nodes to your hearts content. PC, Android, and Apple UIs all work great. Dead simple to add additional nodes, etc. I have "guest wifi" - no password, isolated, slowed down, lots of cool things you can do with it.
K
kbuhagiar
Escondido, CA
I'm eliminating the Unifi because, although it appears to be a great system with infinite options, I'm past my geek-out days with Internet devices. I'm more of a plug-and-play guy now; I'd rather spend hours in the garage with my cars, rather than fiddling with my tech devices.
I just read the following online:
"On March 25, the Federal Communications Commission issued a notice that the sale of new foreign-made routers will be banned going forward. Virtually every Wi-Fi router available for purchase in the US meets the FCC’s “foreign-made” criteria. As of April 22, Netgear and Eero are the only consumer routers that have received an exemption. All the other routers we recommend on our best list have previously received FCC approval, but there’s a risk that they won’t be able to receive software and firmware updates after Jan. 1, 2029".
So it looks like, for me anyway, the only two candidates are the Netgear Orbi and the Eero. And right now I'm leaning towards the Eero, mainy because of the cost difference. And I like the subdued profile on the individual nodes, but I can be swayed over to the Orbi if performance and reliability is substantially better.
Thoughts about the above mentioned FCC notice?
And more pros/cons on both the Orbi and the Eero, please.
Thanks!
larry4406
Northern Virginia
I’m far from a techie, but I set up our Orbi with ease.
Even connected an Ethernet cable to the Xfinity router so I could put it into bridge mode and let the Orbi handle all traffic.
Later added a new RBS750 satellite to the system. Had to update its firmware but that was it.
Point being, if I can do it, anyone can.
Skellyii
KC Area
I've had the old Google pre-Nest Wifi stuff for probably 6-7 years in two different houses, both around 3,000 sq ft.
No issues. You can get the older stuff on eBay for pennies.
Bad Habit
Chumstick WA
I can't remember when I got my Orbi, 10+ years I think. RBR50 and RDS50 Satellite. Originally picked it because the satellite has ethernet ports and I can run a PoE switch for cameras off the shop. Been rock solid.
tez929rr
Welfare, TX
I had to look up which mesh routers I had - and was surprised to read that it’s been 8 years. Never any problems that I can recall.
Punkinhead
I dumped my old Google mesh this year for TP-LINK Deco. It works fine and the speeds are great.
I recently did the same. The Google nodes kept randomly disconnecting. So far, so good with the Deco units. I like that I can do wired backhaul from the node in my barn back to a wireless node in the house that isn't the main router. I assume that's something any modern mesh system can do but the Google units couldn't since only the main router had RJ45 jacks. My main router is in a place that would be very difficult to connect with a wired connection to the barn.
Hooked
League City, Texas
I've been running Eero since Frontier finally got cable to us about 6-7 years ago. I have 3 nodes, two in the house and one in my workshop 175' away. Can't recall ever having a problem with them but do have to reboot the Frontier router on occasion.
67King
Friendsville, TN (Knoxville area)
We have the eero, and it hasn't quite been as simple for us, but once the kinks were worked out, it has been. First, the modem we have is also wireless. Can't set it up using the same name as you use for the eero, or the devices get confused. So now we have King for the modem, and Kingdom for the eero. Second was for whatever reason, the repeater on our main level doesn't work for squat if it isnt' hardwired in. Supposedly, only one unit requires that, but our experience has not been that way.
rsparks64
Hill Country Texas
LOVE our Orbi system.
amolaver
I think a lot of this is protectionism.. But tp-link in particular has quite a few legitimately exploitable and exploited devices out there
All devices/software has bugs and vulns, but tp-link doesn't fix theirs.. They're not alone, but lots of better options available.
The ubiquiti gear has been excellent for me and they historically are responsive to security concerns. It is mostly, IMO, kind of prosumer gear and not really PnP, but I'd guess their combo AP/router devices ('Dream Router') are more in that vein. But if you're buying firewall/switches/APs, I think that's reasonable.
My Old Tools
Hamrick Lake, TX
Clearly says "ancient". Mine is their latest. Nobody sends updates after end of life. That's why Microsoft ended support for Windows 10. If you run equipment after the manufacturer has stopped supporting it, you're on your own.
K
kbuhagiar
Escondido, CA
Thanks to everyone who replied.
I pulled the trigger on a Eero 7 system. I hope to have it installed by the weekend.
***UPDATE***
I installed the Eero system today, and so far (compared to the old Nest system) the performance is nothing short of spectacular.
Let's see how it does over the next two weeks.
Interesting to note that I'm getting the same coverage - or better - than my old Nest five-node system with only three Eero nodes.
My garage was always a semi-dead zone but now coverage there is better than ever.
If this keeps up I'll be one happy camper.
BurtEggley
There are quite a few new network hacks out there right now that exploit various brands. The symptoms can be drop outs. Choose carefully. Also, I would manually update the present router to be sure you have the most recent firmware for it. Change the password too.
