suggestions for sliding door
gearman
Im looking for suggestions for a sliding barn style door for a 10ftx10ft opening. Id like to keep the weight down. Im thinking of a wooden frame with metal siding. any thoughts? or experiences? The building is a 14x30 machine/wood shed, and I want one door, to cover one of the three bays at a time.
kbs2244
It will be apx 14 x 10 ?
I would build the frame out of 2 x 6’s with rabbeted, overlapped joints.
Screwed and glued.
I used ¼ ply to provide some racking resistance.
If you do use something lighter you may need some kind of turnbuckles.
djjsr
In the cornfields
You can build a strong and light door by using 1 1/2" foamboard, a 2x2 frame (actually 1 1/2 x 1 1/2) and glue 1/4" plywood on each side. If you're rolling the door on an overhead track, you can make the top of the frame heavier for strength. I built some smaller doors, 3 ft x 8 ft and they probably don't weigh more than about 25 lbs ea.
trbomax
starvation lake,mi.
You can just buy all the corner brackets ,tracks, and hangers at any lumber yard that sells post barns. I added let-in diagonal corner braceing on mine,one on the inside,one under the steel sheeting. Build it,hang it, and get it working the way you want before putting the sheeting on,its a lot lighter that way.
