clownbear69
The title says it all.
Lately Ive been looking at the OTC one but if it is garbage I would like to know
I'm on my second belt on my '98 E150. The first one was in such good shape when I had it replace 50K ago, it is my spare, stored with the jack.How many serpentine belts are you going to change? I don't change them often enough to warrant a kit so I get by just fine with a large breaker bar and a socket.
This belt grabber lifter thing tool is a HUGE help.
http://www.amazon.com/dp/B007QVA9GQ/?tag=atomicindus08-20
I 've found the lang tool to be my favorite. It's rebadged by most of the tool trucks. Shop around for the best deal.
http://www.langtools.com/sku-5333-9-piece-fine-tooth-serpentine-belt-wrench-set/
The Gearwrench set is also very nice.
http://www.tooltopia.com/gearwrench-3680.aspx
Cripe on ebay has a Kobalt version of the Gearwrench set for like $30.
Last time I did one, I used a piece of EMT conduit with the end crushed flat. It was just laying around and worked just fine
That Lang tool looks very similar to the Lisle Serpentine Belt Tool. I recently replaced the serpentine belt on a Honda Civic. To get it off, I used a combination wrench on the tensioner, but it was difficult because of the tight confines and the wrench's offset. Plus, the wrench was much shorter than a serpentine tool so not much leverage. I was unable to use the wrench to get it back on, so I borrowed one from Autozone using the tool loaner program which was the OEMTools 27115 Serpentine Belt Tool. It worked well, but I had to use my own socket since it didn't come with a 19 mm for Honda. My own socket was not quite as shallow, and it barely fit. Putting the belt back on was easy with it. If I were going to buy one, I'd get the Lisle tool though.I 've found the lang tool to be my favorite. It's rebadged by most of the tool trucks. Shop around for the best deal.
