Suggestions on an adhesive
nbpt100
Massachusetts
I am looking for an adhesive to attached a large glass mirror to a frame that became about 50% detached. The frame is a bit flimsy and easily flexes. The original adhesive seemed to have some flex to it. It is not rock had like many epoxy adhesive.
I am thinking of using construction adhesive. I also have some Loctite Extreme glue. I am considering that since i have an unopened tube of it. It says it is impact resistant and will fill gaps.
Any one with relevant experience care to comment?
PCustoms
VT
Silicone.
Pretty sure loctite makes a mirror adhesive. Not sure how flexible it is once cured.
  • Like
Reactions: RPH
N
nbpt100
Massachusetts
Silicone.
I believe that is for attaching directly to a wall. Plaster, drywall, brick. In this case the frame is some kind of plastic.
It will then hang on the wall with a picture wire.
PCustoms
VT
Silicone
LXCam
Dow Corning 732 silicon and it’ll last your lifetime.
Jack Olsen
Los Angeles
I'd probably use Polyseamseal by Loctite. But I'd want to test to see how good any product adheres to both surfaces.
Some construction adhesives are okay, but the product's task is usually just to hold a panel in place while it slowly, slowly cures.
Bigblue&Goldie
3m weatherstripping adhesive seems to stick to anything/everything and is flexible.
RMERR
Northern CA
I've used E6000 many times and I think it would work well for this. Sticks to anything including glass, it's a bit tougher than silicon but still has some flexibility. Relatively inexpensive and widely available.
