scott750
I've been wanting to have decent garage lighting in my 3-car garage. I don't know the exact demensions, but it's about 600 sq ft, has 9ft flat ceilings, and is fully finished (sheetrock & painted).
Last year I installed 5 drop down T-8 twin-bulb shop lights from Lowes. While the light ouput was good, The lighting wasn't always even while working on my vehicles. Here's a quick MSPaint sketch. Forgive me as I'm not the best drawer:
The W/C is an enclosed closet for the water heater and softener. The green box is a switched outlet in the ceiling on a 15a circuit. Right now I have the black flexible cords that normally come attached to these lights strung along the ceiling to the electrical outlet. It looks ugly seeing all 5 lights strung along the ceiling like this and because of the short 5ft length, I can't move these lights into a more efficient position (the 2 outer lights are directly above each car, so the roofs are well lit up). Some of the members here have told me that moving the outer lights to the sides of the vehicles will shine all the light down to the floor where its needed.
So what I was thinking was replacing the central single gang recessed plastic electrical box and installing surface mounted single gang metal electrical boxes and metal conduit tubing. Then I could install electrical boxes in front of each set of lights. I also wanted to install 2 more lights (NEW) to give me more uniform light.
So I wanted to do 6 lights in the 2-car part and only 1 light in the 3rd car part. I only do mechanical maintenance on my vehicles and the current 5 light setup is plenty of light, but just wanted a little more. So the lone light in the 3rd car part should be enough. (My workbench has its own 2ft T8 fluorescent light mounted on the backboard.
Am I on the right track with using metal boxes/conduit for surface mounted electrical boxes? I'm having a difficult time trying to figure out how to go from the central recessed plastic electrical box to mount the surface metal box. Do I have to fully remove the recessed box before installing the metal surface box? Can I use that plastic surface mount electrical stuff or is that only for indoor use? I've read that I will need to use 14/2 THHN wiring. Does that mean I need to buy 3 separate colored wiring (black, white, bare copper) since they aren't in a single jacket? Or can I use Romex 14/2? If I need to use THHN wiring, do I just run the separate wires through the conduit and that's the way it works?
