Sump Pump Gurus Step Inside
mike93lx
Richmond, VA
Alot from what I have read suggests info about heat dissipation and pump material used
Plastic is the cheaper pump material and seems to hold heat in the most
Majority of sites say metal is a better pump material, with cast iron having the best dissipation qualities
Heat never hit me as an issue considering its sitting in water when it's running
LiketoFix
OHIO
Good points! For me the pump is submersed in Cold water and during the winter Ice Cold water so the heat in this application doesn't really apply for me. As much as I'm a fan of Cast Iron and being built stronger and possibly better, I had to replace a Cast Iron Pump years ago due to Excessive rust and Corrosion. So I went with the Heavy Duty Plastic Pump with Stainless Steel Impeller and that was in 2014 and it's still working and I know that I'll be probably replacing that one soon as nothing last's forever.
LtF
D
D45
NW INDIANA
Anyone using a HD Rigid sump pump?
Seems to be manufactured by Wayne
Ridgid 500RSDS has a 5 year warranty and I found one on ebay for $130 shipped (NIB) compared to $250 in the stores
58 Gpm
5200 Gph
4.5 amp motor
D
D45
NW INDIANA
I couldn't pass up the price for the Ridgid pump, just ordered it
$260 in store, $139 shipped online
I'm off next Monday and I plan to redo the entire pit
D
D45
NW INDIANA
RIDGIG 500RSDS was delivered today
The 500RSDS is the new model pump, the old has a 500RSD model number
Time to get some pvc pipe and fittings, vacuum out the pit, and patch the gap in the pipe better
LiketoFix
OHIO
Took the cover off, and I do have two pumps with two switches
Power to the outlet is fine
Yes, it is battery backup........
The backup pump and pump switch does not have a plug, it is wired directly into the backup panel
The main pump and main switch have a plug..........I plugged the switch in, plugged in a lamp, and lifted the switch. The lamp turned on
I then plugged the main pump in and can definitely hear and feel it hum.......how loud should it be?
Everything was coated in sand, some thick and some areas barely any
I will go test the back up battery
Looking at all the Sandy grime on everything that you pulled out of the hole. If it were me I would install homemade filter fabric inside the Sump to filter the water coming in before it got to my pumps and increase the life span of the pumps! JMO!
LtF
D
D45
NW INDIANA
Project done......under 3 hours
I think the Master Plumber pump I removed was still good and the float was only bad. After I removed it from the pit, I manipulated the tether float and the pump worked. I'm going to see how much a new float is and keep this one as a backup.
Anyways, the new pump and new check valve are installed
The old check valve was definitely shot, the valve was stuck open about 3/8" and was very hard to move back and forth
The bottom of the pit had a good amount of sand, that I scraped out really good and used the shop vac to get any leftovers
There also was not any bricks on the bottom, so after I cleaned the bottom out, I used 3 bricks and made sure the main pump and backup pump were supported good and both were not sitting on the bottom
I patched the gap around the incoming pipe, as I think this was the source for the sand......with hydraulic quick set cement.
Tomorrow it's supposed to rain a decent amount, so I will watch the pump area and I'm also curious if there's and change in sound levels. Also hope the vertical float works better than the tethered float setup
Total price was around $200, for the Ridgid 1/2 hp pump, a new Zoeller check valve and a tube of clear silicon
D
D45
NW INDIANA
Here's the old check valve stuck open
D
D45
NW INDIANA
Bottom of the pit and miscellaneous
LiketoFix
OHIO
Just a tip. If your gonna keep it as a Spare you might want to think about storing it in a 5 gallon pail of water with some simple green or something similar after you clean it good. A friend of mine didn't and it seized up. Just an FYI.
LtF
D
D45
NW INDIANA
I need to see if this float switch is even available
D
D45
NW INDIANA
SJE Rhombus Micromaster #102348 is the switch
I can't find it online, might need to send the manufacturer an email
LiketoFix
OHIO
Well I found out a few things.......
1) The battery was indeed NOT charged. It sat on the 2amp trickle charge literally all night and all day today. Finally around 5pm, it was full charged.
I believe the main pump died, the back up kicked on, and completely drained the back up battery
2) The old pump was shot. I installed the new one, and it instantly kicked on and pumped water
3) Bigger issue......I have a buried sump line that goes to the curb. No water is exiting at the curb, even though the exit hole is free and clear
I believe the buried line is frozen, which caused the original pump to kill itself, buy constantly trying to pump.
Now, I need to figure out how to thaw the buried line. I am thinking about cutting into the horizontal line in the basement and installing a "T" PVC fitting and then installing a garden hose fitting, running from the hot water heater and into the "T" fitting
Naturally it's like anything else and the more you explore the more you discover and find out.
Are sure that the pipe is not separated and interrupting flow as a broken or clogged, or blocked pipe will also act like a completely frozen pipe. Just another thought as I've chased many a blocked pipes in my lifetime. A Sewer snake and or camera comes in handy also. Have to be careful with the camera as I've seen and heard some get snagged and lost under different conditions and some were retrieved by digging them up and locating them. Just some thoughts.
LtF
D
D45
NW INDIANA
That issue was fixed 6 years ago when I posted that
The pipe location where it was exiting the house was freezing up so it was wrapped with pipe insulation and hasn't been an issue since
LiketoFix
OHIO
I understand the Time Frame but I do appreciate the info. I'm one who thinks these are great references down the road!
Thanks,
LtF
D
D45
NW INDIANA
I think an old fitting let loose, have a small drip now here
Going to cut it out and replace it with white pvc this weekend
LiketoFix
OHIO
Anytime we're gluing any kind of PVC pipe we always use 2 coats of the specified cleaner with the provided dauber and it not only cleans but softens the pipe and really allows the glue to weld itself together with the pipe!
LtF
  • Like
Reactions: D45
D
D45
NW INDIANA
Amazing how the check valve works, lol
A good amount of water was still in the horizontal and vertical piping......I made the first cut high up and made a mess
ishiboo
Oshkosh, WI
The Ridgid is definitely the same as the Wayne stainless pumps I've had. I have been through probably a dozen of those on several properties. I mentioned it above, but on the Wayne there is a thin rubber strap which connects the bottom of the float's stainless shaft to the pump - on a nearly brand new Wayne purchased to replace a broken one (<1 month) the rubber strap just allowed the float to come right off once.
I will say EVERY Wayne failure other than two have been the failure of the switch. Before I switched to Zoeller, I used to keep a few spare Wayne switches on hand - at the time they could be purchased from Fleet Farm. Looking online, they are no longer cheap though. Wayne/Ridgid parts are absurd. The other two times, one was the motor (I think the seals failed) and the other time was the rubber strap I mentioned - only available for purchase in a $50 kit with the stainless rod and float.
I wouldn't use these pumps anywhere that flooded quickly or in any type of finished basement or one with storage where things could get ruined if they get wet.
BombShelter
State of Hockey
Most new homes didn't start adding drain-tile until the early 80's, yours is most likely a retrofit. The amount of sand is very concerning, are the area ground conditions similar? Does your pump run a lot?
Vertical floats like very clean water or they'll stick, it's probably not a good choice for your situation.
With all that sand, your drain-tile system will eventually fill up and stop working, the water won't be able to make it to the sump basket, I'd start exploring exterior waterproofing solutions and getting roof water away from the foundation. If it fills up and stops working (which is very common), it's hard to fix internally.
I'd also put the pumps on a preventative maintance schedule, pull it out after a big storm, crack the impeller case open and wash it down, getting rid of sand, dirt and pebbles. Make sure the float is clean (and not full of water) and moves easily. Pull the check valve and wash that down at the same time. Most of these pumps will last years if they're not dead-headed or clogged with dirt.
LiketoFix
OHIO
Maybe your talking about PVC Drain Tile which came about in our area in the Late 70's as we started using it and people weren't sure which direction to point the holes. Rule of thumb naturally was DOWN, as Water rises. I always preferred the 3 hole at 6 o'clock and 4 and 8 o'clock. Verses the 2 holes at 5 o'clock and 7 o'clock. Not really sure about that. I've seen Older homes with Vitrified Clay pipe in 12 inch lengths butted up to each other and that was the foundation drain tile from the 40's through the 60's and even earlier with the octagon V.C. Pipe.
I do agree with keeping the pit and pump as clean as possible!
LtF
ishiboo
Oshkosh, WI
That's very dependent on your area. Around here, homes all have basements and have been tiled as long as I can remember - definitely in the 80s it was commonplace. Many have poly pipe from the 60s and 70s that is still in use, and many have clay from well before that!
Sand and dirt is pretty commonplace, especially on the older systems which were less carefully installed. The OP's photos showing that the outside of the pipe has a huge gap is a big source for a lot of that ingress - the tile all collects to the output, and what's sitting at the end of the drain and in the bottom of it doesn't look bad at all IMO. We have a lot of clay here, which is not ideal but there is still a ton of functioning OLD tile. 20 minutes from here, some folks have all sand.
There is nothing to say this has anything to do with roof water or any failure of the waterproofing. Many areas have that much groundwater and the roof may make it worse, but won't prevent you from needing functioning subsurface drainage. If there is an issue with surface water/roof runoff/etc. definitely get that corrected of course, but this could have nothing to do with it.
LtF
Agreed.
It's funny how many folks install tile "holes up"... I can see where the mistake happens though.
LiketoFix
OHIO
Yeah I totally get it. Also as a young man I was wondering which way was the proper way until we thought about it and was taught at a young age that water rises and we went from there making money fixing others mistakes and re installing their upside down pipes! LOL!
LtF
SumpPumpGurus
No its not a Zoeller, I'll check tonight
Purchased at a local True Value, during last replacement
If you need a good quality pump, buy from a plumbing supply. The big box stores have beaten up Zoeller and the other top brands to get them to reduce the price. The lower quality Zoeller in HD/Lowes is the same price at the plumbing supply for the cast iron/stainless/brass model. If you put them side/side you can feel the weight difference.
Sump Pump Gurus
50 S Park St Montclair, NJ 07042
(862) 292-0566
D
D45
NW INDIANA
Well its time to replace the 500RSDS sump pump
Its still pumping water, but i can tell the force it pushes water out has drastically decreased
They most all have a 3 year warranty and it's right around that time
A new check valve will also be switched in
Time to shop online and possibly try a new pump
D
D45
NW INDIANA
I ended up going with:
Wayne CDU800 1/2 HP Submersible Sump Pump
I've always ran 1/2 HP pump but my piping runs probably 100 feet to the curb, so I'm thinking the ling run might be killing the smaller hp pumps?
I think the higher hp pump also has a higher amp draw, so I didnt want to chance it
Hopefully it will be here in 3 days
larry4406
Northern Virginia
We let all exterior piping flow by gravity. We are required to have a 1” air gap between pump discharge pipe and external piping.
This will reduce the back pressure on your pump which may be a contributor to your repeated failures.
We aim the discharge pipe (we use 1.5” pvc) and aim it concentric to a turned up 3” pipe with a minimum vertical separation of 1”.
DGersic
DeKalb, IL
The pump impeller may be worn. If the motor spins, the motor is probably ok for now. You may want to disassemble this pump to see what the failure is.
  • Like
Reactions: D45
