wrigh003
Probably an unusual question, I wouldn't think a lot of you guys have water issues since most of the garages we see are built on grade. Mine's cut into a hill, hence my trouble.
I thought I had my water problem in my basement handled when I got new gutters installed this summer. Alas, I was wrong, and it turns out I don't get water in the basement unless it's REALLY been raining for a while. It's been monsoon season at my house recently, and as it turns out, I have a groundwater problem under my house- when it rains a lot over the course of a couple days, I get water in the crawlspace, and it runs out over the floor of my unfinished basement garage. Nothing down there a little water can hurt, for now, but I obviously need to fix this if we're ever going to finish that space. Immediate/short term solution is to get some more waterproofing in/on the partition wall that separates the crawlspace from the basement, but in the long term, I'm going to have to either put in a sump pump or a floor drain type arrangement there and get that handled, otherwise I'll probably never have a dry/usable basement.
Idea 1: Cheap/low-tech- cut a slot in the slab of the basement floor, dig a trench, run a 6" PVC drain pipe back into the crawlspace and hook a floor drain up with the high point below the level of the basement floor. The pipe would drain to daylight on the other side, beyond the current garage door. Pluses- nothing mechanical to break down or fail- so long as the pipe stays clear, I shouldn't ever have another water problem. Minuses- lots of cutting, trenching, and digging, and I wonder if cutting into a perfectly good floor is really a good idea.
Idea 2: More expensive- Dig a pit, stick a sump pump in it, wire it up and call it a day. On the plus side, should be relatively easy, unless I hit bedrock under my house where I want the pit (possible). Minuses, it probably wouldn't run very often, and I'd think it would have a tendency to dry up and fail/break. Also, not sure how fast a sump pump is meant to work, and I'd wonder if it would be able to keep up under a real heavy rain.
Any pointers? This morning when I pulled off the crawlspace door and stuck my head in there, I had about a foot of standing water, up to the level of the floor in the basement, and the water was starting to trickle in.
Nothing I could do but close the door and go to work- the flooding rains were still coming down.
