I'm looking to put a distributor of mine on distributor machine to check the curve and check it's function in a little more detail and in a more controlled environment than I can do on my machine. I'm located in SE Mass (Bridgewater). I thought about trying to buy one of the sun machines but aside from this tractor I just don't have a use for it so I can't come close to justifying the purchase.
I suspect that my mechanical advance isn't working at all or is working improperly. I do have documentation regarding the specified curve.
I've looked it at on the tractor and I have a very narrow view of the the flywheel and I only have a TDC mark on it. Access is nearly impossible without pulling the oil pan to put some timing tape on it. So I can see it jitter a bit with a timing light as well as what looks to be non-existent advance or advance that is working but masked by the amount of jitter.
It's kind of an oddball, it's a distributor for an 845cc Renault 4 cylinder that is in my tractor. (yes this is the original factory engine)
Anyone with a distributor diagnostic machine in my area would be greatly appreciated!
The tractor just after a semi-restoration last fall:
