I do realize the function of the dwell meter, but was merely guessing as to how it arrived at the reading (resistance).
I recently purchased the Sun machine, so that I can recurve the distributor in my 1976 BMW 2002. I have a Pertronix unit, which I'd installed, but then took back out; because I want to 'fuss' with points. I had been plotting the curve and making some changes to the distributor using an Innova 5568 light/dwell meter, but doing all that over a running engine gets tiresome.
The Sun machine had a very weak strobe when I got it, but a capacitor kit fixed that problem.
I am simply recognizing that it is in need of recalibration and looking for some guidance. I suspect I will be turning one or two of the dashpots in the photo below (I have not figured out how to bring them up into the text).
I also realize the reason(s) they eliminated points, but that is beside the point.
They now make fully electronic distributors to fit the M10 engine, which you can program using your smart phone. You can create and store custom curves, which even make use of a vacuum signal. You can then switch between them using your phone. The "123 Ignition" is Super Cool, but not my kind of fun.
I was in the archives of a Chevy forum earlier, looking for an answer and a member said "I finally sold my Sun machine, when I realized I was spending more time working on it, than I was my car."
