Sunstar SIS75K heater issue
JTB
Traverse City MI
Recently installed Sunstar SIS75K propane heater in my 30'*40' barn. Fully insulated and holds a toasty 45F heat even with extremely low temperatures here in MI.
But I have an intermittent issue where the heater does not light. The draft inducing motor runs but no burn. Talked to the tech department and two suggestions -
- Check all the earths are bonded correctly
- gas pressure at inlet.
With respect to the latter, the Amerigas install measured 11.5 inches at the regulator feeding the black pipe into the barn. After the regulator I have about 15' of 1/2" black pipe upto the isolation valve feeding the flex pipe to the heater. The tech guy was surprised that I did not have a three stage regulator install. He would have expected the main regulator on the tank to drop tank pressure to around 10 PSI, then a regulator at the outside barn wall dropping the pressure to 2 PSI then a third regulator just before the flex pipe to drop pressure to inches of water.
What is the likely hood of only having 11.5 inches of pressure feeding my 15' of 1/2" black pipe causing the actual inlet pressure to fall to a lower than 10 inches and prevent the burner igniting?
Sorry for the long winded post, just trying to describe the problem clearly.
John
Mr onetwo
Coastal Maine
Your pressure is too low at the regulator. I would bump the regulator up to 13 inches water column. You need to test the pressure at the appliance when it is firing to confirm proper pressure. That being said, I would have run 2PSI to the heater with a Maxitrol(vent limiter installed) to cut it down to 12.5 inches.
dfiler2
NW Minnesota
Check the outlet pressure on the gas valve, if this is within the parameters in the manual then I would check the ground carefully and be sure the polarity is correct. I have seen many newer gas appliances have strange intermittent problems when the polarity is reversed.
