Super cheap garage
OK putting everyones creativity to the test, I have a concrete pad beside my house around 20x26 and want to have some type of garage I can do some work in and store my car in when I am not. I have $1000 dollars to spend. Any ideas?
WWShop
MN
Try to find cheap supplies on CL and try to piece something together and hope the wind doesn’t blow it over.
YukonXL04
Arlington, TX
Whew... 1k... not sure what you can build for that. My garage door costs more than that... good luck! Hope you come up with something.
Maybe start looking for a garage someone needs moved? Or keep an eye on Craigslist free pages
nadogail
Coronado, CA
Welcome to the club. I too am always doing everything on the cheap, well as cheap as I can and still get as good as price allows.
Lets start with where are you located?, City, Town, or rural?
How close are you to anyone who might care what your garage looks like?
At this point your options are wide open, it changes when we have to consider how we are going to deal with the world around us.
One of the cheapest walls I have sen was made of pallets stood on edge and tied together with 2X4 lumber. Imagine a Tilt Up building with walls made of pallets rather than slabs.
More later
nadogail
Coronado, CA
More later
bgarrett
Always check materials on Craigslist, then go to estate sales on Friday. You can get very good proper materials and do a job as good as anyone for cheap. Todays estate sale was in an expensive neighborhood. The new owner of the 6000 sq ft house and 2 carports is going to bulldoze the entire thing and put up a McMansion so they were selling anything and everything that you could haul off including a nice 24X30 carport for $100!
finn
The UP, God's country
Find a building that has to be torn down or removed from the property it is standing on.
I was at an auction a couple of weeks ago where a steel sided, insulated post frame building, EST at 30'x40' went for something like $600, with the provision that it be removed in 35 days.
Playwme
The Lucky Country Down Under
Easy. Find something that needs to be removed and remove it.
You just need to find the right one. You guys tend to build in ways that are harder to pull apart. Over here most are built pretty basic. Posts either in ground or bolted to slab, basic trusses that slide into the posts, and metal siding and roof that unscrews or pops off easily. I can pull a standard aussie double down in about half a day by myself and have it stacked on the truck ready to go.
My previous garage was a pull down from work. Oregon frame, bolted together, skilion roof. They were going to bring in the bobcat to demolish 2 of them. I asked the boss when they needed to be down by and if he wanted to save $2000 in demo and dumping costs. Had one down that Saturday and did the other after work on Tuesday. It cost me about $100 to put it back up. Half a dozen stirrups and a few Dyna bolts were all that was needed. I reused all the roofing screws and had the whole thing back up with about 15 hours of work by myself.
NUTTSGT
Northern Central Ohio
I'd come up with a plan first of all. What's your location ? Does your slab have a footer or need a footer for Winter ? Are you capable of doing the work yourself ? That's where you'll get the most for your money.
Are you willing to do it in steps or is a $1000 max and never put another dollar in it ? You can find some decent used material to create a decent shop and one that is permanent if you choose to do this thing in steps, a little at a time. Most of us have started out slowly, doing a bit by bit as we could afford it.
I'd lay a course of block, around the outside to set the walls on. I'd also pin, with rebar, the block to the foundation, fill them and set anchor bolts for the sill. Attach your sill plate and start building your walls. All this time, search local and on CL for deals on construction materials. Find some trusses cheap or wait till Menard's has an 11% sale so you can use the rebate to buy more material.
Rome wasn't built in a day and you don't have to build your garage in one fell swoop. Do it as you can afford it, as you work some OT, side job, sell off some scrap or whatever it takes. In my opinion, why spend $1k on a temp garage when you can take that and get a great start to a permanent structure, that you can insulate for Winter or heat of the Summer.
38Chevy454
Cincinnati, OH
A metal carport, and then enclose it as you find more money or materials for cheap. Even better if you can find one someone wants removed. They are just screwed together, so take a few hours and it is all disassembled and ready to move to your house.
Slednut
Washington state
This is what I did but all at once. Bought a steel frame online and the metal siding and roofing locally. Found a couple 7x9 doors for free that I cut down (height) so they would fit. I then found some used 2x4s and framed in the rear and covered it with OSP. It was still way over a thousand dollars though. I think the steel frame was around $800.
Kaizen
New England
realistically I'd use a tent garage 12x20. got mine from tractor supply 320 bucks. lag it into the concrete and it won't move. material will last 2.5 to 3 years. weatherproof.
sorry its been a while since i posted, i had a tent style for a few years and got tired of it, i have been looking local for a deal on a building to take down but in my area its slim pickings. I am leaning heavily toward a carport and close in as money allows. Im a mechanic at the local ford dealership and dont have a lot of spare time to go to auctions. I have an exising concrete pad its not huge but usually have two cars parked on it. I am thinking about a 12x26 or 12x31 maybe go 18 wide but not sure yet as if i go 18 wide its gonna kick the second vehicle (my womans ride) into having to park in the gravel.
thinking about a metal carport and closing it in later is best idea i have so far
Actually a good idea ! The biggest problem you will have is putting a garage door on it.
If this is your long term plan, spend the extra and get a carport that has eaves. It will look much better in the end.
jives
Central NY
I built a 20 x 12 shed almost entirely of scavenged materials. Fashioned studs and rafters/trusses from 1" x 4" packing crate material used to hold furniture. On my way home from work I picked up the crates/pallets from a furniture store I passed on my way home everyday. Dismantled the crates and pallets, and eventually glued and screwed the 1 x 4s together. Those were the studs and roof trusses. Incredible amount of work.
Some of the pallet wood was rough sawn hardwood, 1 x 4, 1 x 5, about 6-7 feet long. Not your typical pallet. Sided the hold shed with them. Picked up used plywood for the roof deck -- anything from old cabinet doors to construction waste. Shingles were $5 per bundled, mismatched from the Wickes Lumber surplus pile. Other scrap lumber and windows from CL.
Took way more time, effort, and money than anticipated (glue, nails, other hardware, shingles, roofing felt, PT lumber for the base). Ripped down every board for straight sides for the siding. I think the whole thing cost me about $800. Took about 1 year of collecting and CL trolling to get the materials. Another 6 months to dismantle the pallets and turn them into usable lumber and build the shed. It was fun while it lasted, and real challenge just to see if I could do it. But never again.
jives
Central NY
