Super deal on test lead kit
owenst7
Anchorage/Reno
Just noticed this thread. Been shopping for some leads for a while. Ordered two sets so I can give one to a friend who's a truck mechanic.
Every time I browse here I end up buying more tools Lol.
bonacker
Mine also came yesterday. Archie, thanks for the fast shipping and the set will be used a lot by me.
readymix
Thanks for the link, I just bought one for myself and then 3 more for the shop.
signcrafter
I came home to a second set the other day. Archie was nice enough to send me another free one for starting this post and helping him sell so many.
Thanks Archie! :beer:
BirdMobile
Picked up mine at the post office about 10 min. ago. Haven't opened it up yet... but the package looks like it's the right shape and size! :)
Buckgnarly
VT
So I have to ask Archie, how the hell does one acquire this many kits?.....oh, and you do not have to answer!....:evil::thumbup:
abk241
SF Bay Area, California
A close look at the ebay listings pics and the grainger sites pics seem to indicate that these 2 sets are not identical.
That being said...you can't go too far wrong for $65.00
Jacobson
The adapters for the different pins you can use to test different things. Say your power window motor(or fuel pump, or cooling fan, or any component in the car) is working. You can unplug it from the connector and hook these adapters up to the pins coming from the car side connector. Hook your meter up and see if you have power. There are many ways to test and you can test this with a test light. but these go onto the terminal pins so you don't have to hold it and balance a test light on the pin. So if you are going to be testing for a while you can just keep your meter hooked up and don't have to keep going back with a test light each time you do something to see if it fixed the problem.
Also you can use these adapters with a PP3 so you can send power to something. Using the same window motor example you can hook these adapters up to the window motor connector and connect your PP3 and send power and ground to the window motor to see if it works. Yes you can hold the PP3 pointed tip on the connector to do the same but sometime it's nice to have a solid hook up. And I ran into this last week where I couldn't get my pp3 tip to the window motor connector so in that case I could have hooked the adapters up as an extension and been a lot easier. They are a good non intrusive way to get into wiring harnesses for testing.
Can we discuss the purpose of this kit a little bit more?
In the window motor example above, you connect the car's power plug to these leads, which then plug easily into your DMM? Instead of holding pins and test leads....
Or, you can plug these leads directly into your window motor, and then connect the other end to a power source? Again, don't need to hold everything in place.
Is that the basic idea?
signcrafter
What part doesn't look the same? The ebay pictures and the grainger look exactly the same to me. Also look at my pictures above of the kit I received, the same as the ebay add and grainger.
Pretty much. The different adapters fit different pins in your cars connectors. So you don't have to steady your meter leads on a positive and negative pins that are close together in a connector. Makes it easy so you don't have to hold everything and also prevents you from having a meter lead slip and touch two pins and cause issues like blown fuse or fried computer. Also they plug right into a PP3 if you have one so you can easily power up a window motor. There are lots of advantages to using those adapters. But it is also a quality set of test leads that are all plug and play with each other. So you can easily change tips from pointy to alligator to back probes to the adapters to an LED test light. So many options to cover most electrical testing you will do.
BirdMobile
Just opened mine, TRULY a bargain for the price!
The case even has room to store a small DMM (I put my Cornwell automotive DMM in mine...) to the left of the battery clamps area.
Very happy with my purchase - I'd buy from Archie again.
Jarhead0408
Who knows?
Just got mine in yesterday. Finally opened her up today!
Wow! I wasn't expecting this set to be so large and to have so many extra leads! Gotta say, I'm pretty stoked about it!
Looks to me like we all got a pretty good deal!
Noted-Veronica it is. That means I get Betty all to myself!!!
larryq
Mine arrived today, looks like a quality set. Ebay feedback sent, thanks Archie!
nanofrog
Does anyone know what the wire insulation material is (PVC or silicone)?
Thanks. :)
Mohawk Dave
SoCal
I HATE messing with electrical. Therefore I just ordered a set, b/c anything that makes testing easier is worth it.
Archie, thanks for coming on GJ. Way to go.
Regards, Dave
wild cowboy
Birmingham
I see about 9 or 10 different connectors, in both male & female, but I am unsure which manufacturer's connectors this kit fits?
I would like to find something like this that includes all GM connectors, or all Toyota or whatever.
Jbullfrog
Avoca, Iowa
there are 2 sizes of Deutche, 5 sizes of flat micro pack, standard bullet, and spade, back probe needle, and to clamp on. All have standard multi-meter banana jacks on the other end. 3 of each test lead, 2 3-wire pots, 2 led test lights, and 4 extension leads with male/female banana jacks on both ends.
signcrafter
Here are some pictures I just took showing a window regulator and using my powerprobe to send power to it. The two pictures with my hand just to the left of the motor my hand is representing the metal in the door. I was testing a malibu window motor and there was a metal panel just to the left of the connector so no way to get a powerprobe in there. But you can use these leads to plug into the motor and act like an extension to get around that metal panel and be able to send power to the motor. There are a million other uses but this window motor example was one that I had in the last couple weeks and is a good example of how handy this kit can be.
I really like how it is all plug and play with a power probe. So between a fluke and a power probe and this kit you have so many options of getting into the wiring without poking holes in the wires. And it's a "solid" hook up. I used to have alligator clips and all sorts of other things hooked together to test and sometimes they would come apart. Or I would have to hold my meter leads or PP3 tip on a wire or terminal pin and try to keep it from slipping off while turning the key or pushing a switch to the window motor. Now I can hook everything up nice and just have my meter where I can read it and have both hands free to push buttons or turn the key to test and not worry about my leads having a good contact.
Window motor
Trying to use a PP3 to power it up to test it. Have to use alligator clip and pointy tip that can slip.
PP3 hooked up with test lead adapters.
Hand showing where a metal panel was on a malibu I tested the other week and couldn't get a PP3 in to power up the window.
Showing test leads act as extension allow you to get power to the window motor.
All the PP3 leads and the test lead kit use the same 4mm connectors so they all plug and play together to make a ton of different testing options.
Just one option of a PP3 hooked up to a backprobe.
It has the common round, square, and rectangle male and female ends. I have a kit from these guys http://www.jumperkits.com/jumperkits which I have been using but isn't as nice as this set. If you have ever priced terminal kits made just for GM they are crazy expensive, in the several hundred dollar range. I haven't found a set made for toyota. Several companies make test lead kits like this but they are in the several hundred dollar range also.
Deadhead
Northeast Arkansas
Ordered a set this morning on break.
Showed 2 coworkers and one of them bought one while standing there by me. 2nd guy said he was going to after work.
I have needed a set like this for months if not a year.
As for the how's and why's of having this set. It helps to plug into a connection in the cab of a combine and have it stay firmly in place while you climb down, walk to the back, and climb up near the engine and test things 15-20 feet away.
larryq
Outstanding writeup, thanks for doing it. :thumbup:
pi_guy
N/A
Got the set Archie thanks!
My only question is what is with the black Y connector, to me it is useless unless you own a power pro. What makes me crazy is it is the same spread distance as the inputs on one of my Fluke meters. I have a lead set that has a Y connector and fits the Fluke. I have not checked my other meters yet to see if they have the same distance but it is a common setup to have paired leads.
Jacobson
What is the benefit of the power probe when you can just buy some aligator clamps and a long wire to your car battery? Is it more suited for non-auto applications?
Jacobson
Is anyone planning on tossing out the box, and just storing all the leads in a small bag?
I bet a handful of leads takes up a lot less space then the box,,,
Jacobson
Signcrafter, thanks for your photos, now the kit makes a lot more sense.
Makes things much more convenient for someone doing a lot of testing.
signcrafter
The only thing I thought they might be for was to connect two of the adapters together. I think they are just basically a Male to Male adapter. The yellow ones with another post on top I think are for a break out type of adapter where you can separate a connector and then using the terminal adapters and they Y adapters you can still complete the positive and negative of a circuit and then hook your meter up to the top post of the Y and monitor the circuit while it's working. But maybe someone else has more ideas.
The PP3 is suited for auto applications. You can use a jumper wire but the PP3 is quicker and easier and has a nice switch. It's just another tool.
Nope the box is one of the best features to keep everything organized and just grab it and go to the vehicle and have all the adapters there for testing.
No problem. I was doing a voltage drop test on a starter today and it was nice to have this kit to be able to just grab different pieces and connect them to have the exact set up that would work best.
pi_guy
N/A
After I showing the whole kit to a few people, then I am putting them in a bag.
Most likely mixing them with other leads. I will probably replace some of the connectors with different pins, I do not use spade terminals for example.
RV77
Seattle
Hey Signcrafter -
How about a two week review ? I ordered a set and just curious if you think these will last years if used respectfully ? BTW thanks for the link.
Thanks
BirdMobile
Archie sent me another kit, free of charge!
Archie is just alright with me
Archie is just alright, oh yeah
Archie is just alright... oh yeah!
Seriously, that guy rocks... thank you!
No problem, brother!
I shipped roughly 100 sets on sunday / monday and I might have shipped a few extra sets... If I did, I figure that's better than not shipping anything at all.
Thanks again everyone for the orders. I appreciate it. Hopefully you all find the sets useful & productive.
As far as longevity... I would say as long as they aren't abused, they should last a while? ie- several years of use? All this stuff comes from China (shocker!) So time will tell about quality...
And some retailers just have a HUGE margin on them...
At 65 dollars, I don't think you can go wrong. :)
Cheers Gents!
EDIT - All orders from this weekend will go out tomorrow ( monday )
Have a nice Thanksgiving everyone!
cuengineer
After seeing this thread, I have ordered mine. Nice to see a vendor who appears honest about his product and seems to want the customer happy. I look forward to getting my set later this week so I can try it out next weekend. To Archie and everyone else, "Happy Thanksgiving!"
gsingh
NOVA
Can anyone put some closeup pics for this set. I wanted to know if it will work on Benz.
MadTinkerer
I had the same set on my amazon wish list but just couldn't pull the trigger. After seeing all the good reviews i ended up picking one up for 100 cheaper then amazon.
I work at a benz dealer as well and i figure any that don't work, i will modify and put some benz terminals on them.
nia573
Wales
Woud you possibly ship these out to the UK, & what would the total cost be please?
Thanks, Mike
Richard Cranium
central Washington
I received my set on Saturday, but didn't pick it up until today. Thanks for the quick shipping.
Just out of curiosity, How many sets have you sold to the Garage journal bunch?
Just another thought, Join the alliance and sell on here and save the ebay fees.. Richie
