Super heavy duty 4 outlet extension cord
mrb
Here is a super heavy duty extension cord. It is 25' 12/3 type SOW cable with a heavy rubber jacket. The male plug is a hubbell 5266. The receptacles are hubbell 5362 20A outlets. The male plug is slightly used in that it was installed on a piece of equipment that never went into service. Everything else is brand new. Its very well constructed (I should have taken pics of inside), ground wire to each receptacle and to the box. These hubbell outlets are some of the best made and cost around $12ea. The cable is really tough and can be driven over, etc with no damage.
Note: these are not OSHA compliant, and shouldnt be used anywhere subject to osha regs. These are not suggested for outdoor use where exposed to water. The flip lid cover is used to keep the outlets free of dirt and grease, im not responsible if you electrocoute yourself because you decided to use this in your pool.
Asking $58 for it. I have enough parts to make one or two more. I can also do with 20a twist lock plug on it.
mrb
im open to offers if anyone wants this.
