That thing must weigh a ton. I'm sure it was nobody's "favorite tool".
I've seen that video before & it makes me want oneThis one is from the 60s.
I bet it was great in rural areas in the 60s and 70s. Probably pretty useful during the boom in housing and industrial developments while adding utilities and such before sites were even sold before actual building. Yep, I bet it was someone's favorite tool in its day.That thing must weigh a ton. I'm sure it was nobody's "favorite tool".
Most likely not left handed. Left handed would loosen every time you pull the triggerUsually there is a hole in the housing to drop a nail into to hold the blade. Might left handed threads in the bolt, so be careful.
This makes no sense. Sounds like the blade is not tight? And you are trying to break a rust corrosion bond on the bolt, without the long lever of the blade as a stop. None of my circ saws came with an open ended wrench, so not familiar with that. Can you find a stamped steel wrench kinda close, and grind it open?The problem with the blade is that turning left the blade stays stationary and the arbor spins free.
