e30bradley
Any plans for a heat shield under the intake?
Yes this has been done for many years though Cleveland heads became the choice in Comp Eliminator.I remember reading in an Hot Rod magazine about a drag racer that used 302 heads cut and spliced together. Apparently the oil and water passages lined up. If I remember correctly it took three 302 heads to make a 300 head. Of course this was drag racing so durability may not have been an issue.
I would think easier, many choices and lots of used ones out there. Plenty of aluminum one which would be much easier to cut and weld.Thanks for the info Mario. I have always been a fan of Fords 300. I just kinda wondered if the 302 heads would make it easier or harder to supercharge.
Also end up with a crossflow head, no intake exhaust interference.
Lot of machining and fitting to make it work
Subscribed, this is going to be fun.
Keep it going, very interesting build, looking forward to moreHonestly, I have no idea just went with it.
As far as heads go, I have had mine CNC ported and will flow right up there with the 302 heads. The only issue becomes everything on the same side of the engine. Even with that I have designed some new flanges that fit much better than anything stock and will work with the aftermarket intakes.
Likely bad memory on my part. I sure would like to know where he got that head !
Here is another Ford 300-6 that has some pretty interesting engineering.
http://www.jalopyjournal.com/forum/threads/300-ford-6-dohc-home-and-running.943107/
Would a 4.0 Aussie six crossflow head fit on a 300?
nope, block isn't dimension compatible
the 4.0L cross flows have been dynoed out to 850hp
Back in the 60's Ford had 2 inline 6 cylinders. The small block (144, 170, 200, 250) and the big block (240, 300). The Aussie 6 cylinder engines are a direct decendant od the small block.
Having said that, I don't know if any of the key dimensions (bore spacing, head bolt locations, etc) have been carried forward.
Any updates?
