Superglue on fiberglass top
Ralf11
I found a few 1" long cracks in the fiberglass top or a small RV.
The cracks are a bit wider than a hairline crack so will need something that can 'fill' them - but they are still less 1 mm wide.
Will Superglue work for this? I don't think an epoxy will be able to get into the cracks, due to viscosity vs. width.
I want to take care of them before they spread.
nadogail
Coronado, CA
I have had a lot of luck using JB WATERWELD to patch holes in plastic shower enclosures and holes in sheet metal.
AZ Pete
Central Arizona
you can heat epoxy with a hair dryer to make it flow into very small cracks. Just put the epoxy on the crack and use the hair dryer (or a heat gun set on low) to blow the epoxy into the crack.
PCustoms
VT
Epoxy or super glue isn't structural, the crack will open up again.
Is it through the glass, or just crazing in the gel coat?
Leaflessshadetree
Don't ask.
Drill the end of the cracks to stop them from going further. If you can get to the back side and add a layer of fiberglass cloth it will also help. Then use resin to fill the cracks and holes.
WarDamnEagle
Auburn
Drive to the nearest boat repair shop/dealer and get them to repair it. Probably less expensive than you think and better than anything you can do at home.
rlitman
Long Island
What were people mixing with SuperGlue ? Baking soda to form a hardening paste ?
That does work. But it won't help the OP.
Cracks in fiberglass cannot be repaired with just a little adhesive of any sort. They're a sign of flexing in ways not designed for. Perhaps something is damaged under the glass, or it needs more glass reinforcement.
