billt460
Around here most homes are heated by heat pumps. It doesn't get freezing, but it can and often does drop down into the high 30's this time of year at night. (December through February). I've found heat pumps just don't work that well, and are expensive to run.
The house came with a small propane RV type ventless catalytic heater that was set in the fireplace. It worked OK, but didn't provide much heat, and was difficult and time consuming to light. So this past week we purchased a "Mr.Heater" brand 30,000 BTU ventless propane space heater. This thing is fantastic!
We placed it right in front of the fireplace, and it was easy to hook up to the same gas line the small heater used. I didn't even have to change the regulator. (It is piped to the propane supply outside). This heater is very easy to light, and has a built in thermostatic control that works really well.
It provides a clean, even heat that circulates through much of the house. Especially if I keep the ceiling fans running in both rooms. The thermostat turns it on and off as needed to maintain an even temperature. We have no kids, and our dog loves laying in front of it.
We don't leave it on unattended, or while we sleep, because it's really not needed until the early morning hours. Both my wife and I are early risers. So whoever gets up first makes the coffee and lights it. (We're both retired).
I like this thing so much I'm going to get another one for my large, (1,000 sq. ft.), 3 car garage. I have insulated doors on it, so it will be nice and warm when I want to reload out there in the colder weather.
I just thought I would mention it if any of you guys are in a similar situation, and require a supplemental heater to provide some extra warmth in either your home or garage. This thing is worth every penny! They are available in different BTU outputs. And in either propane or natural gas models.
