Supply valve with 4' handle
denis4x4
Durango CO
I have to replace a leaky supply valve that is probably 45 years old. I would like to use something with a shutoff that is easily reached. Using a 4' rod is a PIA. Current valve is down 4' as it is in Colorado. This is a vacation home and I want it to be quick and easy to turn the main water source on and off. Point me in the right direction for a good source. Thanks in advance.
sixty4
CT
I have a friend that lives in upstate NY that he uses as a summer home (he shuts the place down for winter_. I got him a curb stop extension that really saved him. Not sure if this is what your after or not?
jubilee
Colorado
If you have electrical nearby, you can buy 12 volt solenoid valves you can control with your smartphone, computer, ect. 3/4" wifi controlled valves for sale now on EBay and Amazon. Or you could hard wire a switch to a non wifi
If you have electrical nearby, you could wire in a 12 volt solenoid controlled valve. Hard wire switch anywhere you want. Or, wifi solenoid valves are available you control with smartphone,computer, ect.
readhead
Durango, Co.
Call Grand Junction pipe. They should have curb stops and the key. I suppose you would want me to bring my backhoe over to dig the hole.
