Surface mount outlets
bdamico
lots have and I'll tell you there is no mystery, trick, or technique
The outlets (receptacles) are no different. You need to buy a box that is designed to be surface mounted. I like this style. They are galvanized and with galvanized covers, they have a nice "industrial" look.
If they are to be mounted on a finished wall, you will probably need to run conduit.
Norcal
The "handy box" shown above is one of the worst pieces of sh*t that is on the market, using them is like trying to shove 25 pounds of **** in a 5 pound bag. The 2nd one is not much better. 4 square boxes & raised covers work much better.
#1SomeGuy
Canada
I did two extra outlets with surface mounts and used bx cable...has worked fine for a couple years. Just screw the boxes into the studs. Easy way to add circuits to a finished garage.
Charles (in GA)
50 mi south of Atlanta
The second box is a double switch box, and you mount switches or receptacles and use standard cover plates. Looks tacky because of the way the cover plates fit as they are made to be installed tight to a wall surface.
Better off with a 4x4 box with the tabs in the diagonal corners that takes various covers that switches or receptacles mount in.
Steve.S
Cincinnati, Ohio
I second that. These have a "bump-in" that's threaded for a ground screw...makes it a lot easier - no need to drill a hole to allow for clearance behind the box. That's especially helpful when installing on a masonry wall. :thumbup:
bseant
central valley,cali
x3 nothing worse than a crooked or wobbly surface box because the wires wont let it sit flush.
