Surface Plate Advice
scratchedup
Fayetteville, GA
I am looking for a general purpose surface plate ...say about 10" x 15".
Looking for advice on metal vs stone, what to look for and where to purchase.
THX
B.S.A. (ret.)
Central Connecticut
Depends on what you're going to be using it for. I always preferred granite when I had my tool & die shop, but some people have had good results with steel. Judging by your location, I am wondering if humidity will be an issue with a steel plate. If so, I would lean towards granite. Also a good idea to have it calibrated before using for precision work.
bcradio
New Mexico
Starrett, Standridge, and Mitutoyo are all great brands for granite plates. You might be able to find some used ones in your area that will save a good bit of cash. They may need to be calibrated though if you are doing precision work.
FTG-05
TN
Call around to your local granite counter top guys. I had a pretty big piece left over from my granite counter top project and I kept it to make a surface plate. But then we moved and didn't have room for it. Out onto the street it went, never to be seen again. Dumb move. :(
I asked my granite guy and he said no one ever asks for the leftovers, it's just considered trash.
Good luck!
rlitman
Long Island
Good luck!
Granite countertops are far from precision ground. They're wavy as heck compared to an actual surface plate. Also, the stone itself is often pretty different. Surface plates use a fine grained granite that looks pretty blah as a countertop, though "black galaxy" is close to what's used for surface plates.
Sink cutouts are cheap, granite tiles are cheaper. If you're looking to do scary sharp, glass is flatter and smoother, so it will work much better. Actually, a thick piece of float glass is a much better all around surface plate than scrap from a granite shop.
A cheaper option than the big brands for a real surface plate is Grizzly. A 9x12 is around thirty bucks, with the 12x15 being closer to fifty.
pstemari
Seattle
MSCdirect.com and KBCTools.com also have very inexpensive import surface plates.
Sent from my Pixel XL using Tapatalk
dr_clyde
Holland, MI
Granite surface plates are better for inspection and general use. Cast iron is preferred for lapping. Granite is more stable and wear resistant, which is nice for an inspection surface. Cast iron can be charged with lapping compound for making precision surfaces.
Granite plates are graded, B for general shop use, A for inspection and toolroom, and AA for lab work and for machinery like a CMM.
Generally, Grade/Flatness is a function of flatness deviation per inch or several inches, and repeatablity per inch. The size of the plate is directly proportionate to the difficulty to lap in and maintain the grade.
Grade B Toolroom-100 millionths
Grade A Inspection-50 millionths
Grade AA Laboratory-25 millionths
From Starrett: "The flatness tolerances for three standard grades are defined in the federal specification as determined by the following formula:"
Laboratory Grade AA = (40 + diagonal squared/25) x .000001" (unilateral)
Inspection Grade A = Laboratory Grade AA x 2
Tool Room Grade B = Laboratory Grade AA x 4.
If you follow the rule of thumb that your inspection device needs to be 10x the resolution of whatever you're inspecting needs to be, that will give you the range of what plate you want.
B is more than good enough for home shop use. If you can luck into an A or AA that's all the better. If you truly need the flatness of A or AA you'll want to have a company come in and lap it in. AA needs to be in a climate controlled room with very fussy instruments to keep its tolerance.
Starrett's pink granite is very nice, and I've heard great things about Standridge plates.
If you look at pretty much any machine shop auction, they are usually for sale and can be had for less than $100.
They are incredibly useful, I wouldn't be without mine. This one I got for free. Used to be part of a large CMM or some kind of inspection machine. Roughly 3' x 5' and 2000 ish pounds.
stonesg
SE Georgia
I didn't see the post above my last one some how... By, "that size" I was thinking 12x18 inch ish... Not that monster!
FTG-05
TN
I wouldn't have expected them to be precision ground but probably good enough for a typical residential shop.
Can you give some numbers to show the difference between the typical granite counter tops vs. low grade surface plate? How do they even measure it?
What are the OP's requirements for a surface plate?
rlitman
Long Island
Of course I can't give you numbers. That's the whole problem. Surface plates have a guarantee of flatness. Granite countertops do not. But from my experience, they're no flatter than a piece of MDF, and often far less flat, due to variations in consistency of the stone across the piece. The resultant "flat" surface is like a piece of wood sent through a thickness sander, with softer regions forming valleys, and harder parts forming ridges.
Is that sufficient for a residential shop? Perhaps. But if you have a Blanchard ground saw top, that's sure to be far flatter.
FTG-05
TN
I can, now:
FLATNESS TOLERANCE
The flatness deviation of a local area of 250 mm x 250 mm of the working surface shall not exceed :
1. 3.0 µm for plates of Grade 00
2. 3.5 µm for plates of Grade 0
3. 7.0 µm for plates of Grade 1
4. 15.0 µm for plates of Grade 2
5. 30.0 µm for plates of Grade 3
Of course, I have no idea how a residential (or commercial) shop would measure the above unless it was an actual SP with a cert.
And here are how the various grades are used:
Granite Surface Plates are manufactured in five grades. The typical application of these five grades of plates is as under :
1. GRADE 00 as per DIN : 876 : 84 is of laboratory grade. It is specified for precision measurement in gauge rooms and metrology laboratories for calibration masters.
2. GRADE 0 is of inspection grade. It is specified for general work in quality control.
3. GRADE 1 is of tool room grade. It is specified for production checking work through the shop.
4. GRADE 2 & 3 are intended for use in shops for general inspection. The choice of Grade 2 & 3 will depend on the application needs of the customer.
Got it from here: https://www.gmt.co.in/granite-surface-plates.html
So what are the OP's requirements?
Packard V8
Spokane, WA
Agree; what's he building and what metrology does he have available to reference off the surface plate.
Some years back, I picked up an 18" Starrett pink granite with stand and cover for $100, just because it was there. I seldom-to-never use it and should pass it along to someone who needs it.
jack vines
rlitman
Long Island
I can, now:
FLATNESS TOLERANCE...
Yes, exactly. The tolerance numbers for actual surface plates are published. What I could not provide numbers for are for granite scraps from a countertop shop, as their tolerances are simply "does it look ok and is the customer happy with it".
scratchedup
Fayetteville, GA
My requirements for now are kinda general for now. I am still at the "building up my shop stage".
Possible projects might be exhaust & turbo flange lapping...maybe knife sharpening wet stone flattening and just a general flatness reference gauge for assorted projects.
A lot of this stuff is pretty new to me. I am pretty much a home hobbyist soon to have a lot more time on my hands with pending retirement.
Thanks for the great response.
Alchymist
Central PA
One could always take 3 pieces of that granite countertop stuff and start lapping. Lap 1 & 2 together, then 2 & 3, then 3 & 1. Rinse and repeat until they stick together when clean from their own weight. Shouldn't take more than a month or so. :lol_hitti
rlitman
Long Island
:) That's not as crazy an idea as it sounds. And it would work, IF you chose granite that had a fine and consistent grain. Like the black galaxy I mentioned above.
The slates from a pool table would be easy to get exceptionally flat in short order like this, though slate is also not all that resistant to abrasives, so it wouldn't stay flat for long, unlike a good pink granite.
But the three plates method won't get three pieces of pine flat like that, no matter how long you rub them together, as some parts will wear faster than others, and most granite countertops have visible grain, simply because granite is rather boring without it. That's something you'll never see in a good surface plate.
Of course, if you did this with granite, the cost of the diamond paste needed would probably exceed the cost of just buying a new and certified surface plate.
zmotorsports
Northern Utah
I have a Starrett 12x18 toolroom grade that is more than accurate for what I use it for.
I would suggest trying to find one locally because with the weight, and in some cases fragile nature, I would be hesitant to want to ship them. I would imagine it would be expensive to ship due to the shear weight.
I picked mine up from a local shop going out of business sale about 15 years ago.
Mike
larry_g
oregon
Sounds to me like you need a lapping plate, different than a surface plate.
lg
no neat sig line
