I'm watching a YT restoration on a 1971 mower. Their using a small surface plate and some kind of compound to lap the top of the cylinder flat. Is this a typical use for a plate?
If you aren’t a professional machinist, tool & die Maker, patternmaker, or got the plate cheap, it is not unusual to misuse a plate like that.I'm watching a YT restoration on a 1971 mower. Their using a small surface plate and some kind of compound to lap the top of the cylinder flat. Is this a typical use for a plate?
Used surface plates go pretty cheap at auctions
What is flat? Are you needing surfaces that will wring together or just straighten out the warp in a cylinder head. like the op's example? In the op's example the process is to make the bottom of the cylinder head flat enough that it will conform to the gasket between it and the block. The measurement of Flat to a machinist is a lot different than the measurement of flat to a concrete finisher doing a concrete floor.That doesn’t work the way people think it does. Sandpaper on glass or granite doesn’t make the surface you rub on it flat. Lapping plates are really different. It might work well enough. But rubbing something on a flat surface absolutely does not guarantee it’s flatness.
That’s the right way to flatten with a surface plate. A biax is a little overkill for a lawn mower cylinder head. But if you’ve got one, I guess why not use it. If I were doing heads, I’d checked them on the surface plate and fly cut them on my bridgeport. Rubbing them on sandpaper can easily make them convex.I use a surface plate to straighten heads out still but blue the head up on a surface plate and scrape it in with the Biax.
Good thinking.Glass shelves from the fridges work great. Glass is close enough for most diy clean ups. It’s easy to find and replace when gone.
For non critical parts some people just use a polished concrete floor. Not me, but I've seen it.
Just for kicks, if you want to use a surface plate as a lapping plate, do what you want, then blue up the plate and check. But be prepared to be disappointed.
I can recall scuffing used ones with sandpaper or sand blasting and thinking that was quite primitive. Scuffing the steels on concrete must have made them pretty grabby. "another race or two" indeed.We used to resurface smoked motorcycle clutch plates on the parking lot concrete. Not ideal but it'll get you through another race or two.![]()
I helped a friend with a street/drag bike, never owned one myself. Your photo reminds me of the natural resting position of motorcycles.
