billt460
I had a palm tree stump in my backyard about 4 ft. high, that was left by the previous owner. It looked like hell, and I wanted rid of it. The landscaper who does most of my trimming and cleanup wanted between $200 and $250 to rake the gravel back, and dig down to cut it off flush with the ground, and haul everything away. I felt that was reasonable, but I held off trying to think of another solution.
I came across several Chinese chainsaws on Wal-Mart's website that were priced very reasonable. One in particular was the 20" bar, 62 CC Salem Master Pro. It was only $160.00 delivered to my door. I watched several You Tube videos on it, and most everyone was quite pleased with the unit, so I ordered one, and figured I'd do the job myself, then basically have the saw for free. I also ordered a 4 pack of air cleaners and a extra chain, along with a 5 pack of spark plugs. (I figured that being a Chinese product parts availability is going to be limited, to nonexistent).
The unit and extra parts all came well packaged, and I assembled the bar and chain, adjusted the chain tension, and gassed and lubed it up. It started on the second pull! The unit requires a 25:1 mix, and they give you a nice gas / oil mixing bottle that will mix about a liter of fuel. I used a 20:1 ratio for the first couple of tankful's to break it in. The chain oiler works very well, and is adjustable from "Low" to "High" with the turn of a screw.
It cut through that 24" palm stump like it was made of paper mache. The actual cutting time was no more than a couple minutes total. (I made a total of 3 cuts through it). The cut wood was very light because it was void of most of it's moisture. It took 3 times as long to clean everything up and put all the tools away, than it did to do the actual cutting. I tossed the leftover wood out with the trash. Afterward I blew off the saw, and wiped it down with some WD-40 and Silicone Spray on all the plastic. And it looks like it just came from the box. After I raked everything back, you can't even tell a stump was ever there.
I wasn't about to pay $400.00 to $500.00+ for a Stihl or Husqvarna saw to do this, because I don't need a saw that often, let alone one that requires that kind of quality. In fact, I don't know when, or even if I'll ever need one again. But for only $160.00 this saw performed amazingly well. It has plenty of power, cuts like butter, and is easy to service and handle. I purchased it through Wal-Mart, so if it should tank within the warranty period, I can easily get a refund.
If anyone is in this situation, where you need a saw for a one time job or occasional use, don't hesitate to buy one of these. They're surprisingly well built, run good, and have good reviews. And for the price, you simply can't beat it.
